It is currently Tue Aug 12, 2025 10:03 pm
PostPosted: Tue Nov 11, 2008 10:24 am
..........Mini Cooper 1.3i.
Means i cant get the wheels off so whats my best option ? How many combos did they make ? How bloody frustrating
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Tue Nov 11, 2008 10:36 am
When I lost my lock nut socket I just smacked a socket over the lock nut and undid it that way, rough, and I needed to replace them, but it got them off.
try multi grips?
PostPosted: Tue Nov 11, 2008 10:47 am
I do the same trick as above. Get a chinese socket a smack it over the nut and undo it SLOWLY.
I'd then get a new set of nuts or locate a correct key thing, but a mate of mine has used his "home made" key on the car for years without trouble. The wheels are on and off dozens of times. :D
PostPosted: Tue Nov 11, 2008 10:52 am
Ok - So realistically, there not much good anyway if there easy to get on and off like that are they ? ;-)
PostPosted: Tue Nov 11, 2008 10:55 am
i scrapped mine.. they're a pain in the arse.. need to carry the lock nut socket, plus another socket to fit that as its different size to the other wheel nuts, plus a ratchet to fit the socket.
if someone wants to pinch my wheels, and god knows why they would.. they will find a way regardless. and it be a good excuse to buy some Revolution 6x10s....
tim
PostPosted: Tue Nov 11, 2008 12:28 pm
My bad !! After having a good ( rear much better ) look in my original tool kit i found it. But, it was in a weird little sleeve so managed to fix my tyre ! Back in business ;-)
Users browsing this forum: 1071 S, Bing [Bot], norton and 259 guests
