It is currently Fri Jul 18, 2025 12:36 pm
PostPosted: Sat May 01, 2004 7:04 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
hey,
im after a place that can get me in a few liters if good quality metalic paint cheap as well as the primer bog and the rest so i can start my spray job!!
let us know!
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Sat May 01, 2004 11:37 pm
Last time I bought paint I got it from Autolac.
They sell Dupont paint, which was used on minis from the factory and is great quality. they have stores in Brookvale (9905 1388), Artarmon, Taren Point, Girraween and Cardiff. I just went in and looked through the 2-pak colours and picked out one I liked and they made it up in acrylic - be warned though a few of the 2-pak colours don't have a acrylic mix code for them (they are usually the ones I pick first - just my bad luck).
One thing I would recommend with the metalic paint is that you use a clear coat over the top as it is known for the metalic flakes to rust (or corrode in the case of alluminium) in the surface of the paint.
They boys at autolac recommended a "special" dupont clear to me which I tried with great results.
all up it cost me about $300 for 4 litres of colour mixed to order, 2litres of white mixed to order for the roof, and about 3 litres of clear.
give em a ring and see if they can help ya!
Ben
PostPosted: Sun May 02, 2004 7:46 am
sweeet,
i work just up the road from autolac at artarmon,
so u recomend them....THATS GOOD!!!!!
cheers for that, very much appreciated!
lobstar!
ausmini member 195
