Engine Rebuilders https://www.ausmini.com/forums/viewtopic.php?f=2&t=47776 |
Page 1 of 2 |
Author: | dezynablue [ Fri Nov 21, 2008 9:51 am ] |
Post subject: | Engine Rebuilders |
Hi All, Just a quick question, I'm rebuilding a 1098 engine, would anyone know a good reliable company for head machining, crank re-grinds etc in the NSW, Windsor Area. I could always take a firm grip on my wallet, hit the yellow pages and pray but thought id ask if anyone had used someone they would recommend. Cheers Johnno |
Author: | Monster Mini [ Fri Nov 21, 2008 10:07 am ] |
Graham Russell is the God , North Rocks ph: 96302195.. ![]() |
Author: | miniDave [ Fri Nov 21, 2008 10:11 am ] |
I would talk to Graham Russell. (02) 9630 2195 When my engine was done, Graham sent the head to a company in Hornsby. He can do the crankshaft and milling in his own shop in North Rocks (near Parramatta) Regards |
Author: | Wombat [ Fri Nov 21, 2008 10:27 am ] |
GR is good enough for me to send my engine to him from Brisbane ![]() |
Author: | 1310/71 [ Fri Nov 21, 2008 10:52 am ] |
miniDave wrote: I would talk to Graham Russell. (02) 9630 2195
When my engine was done, Graham sent the head to a company in Hornsby. He can do the crankshaft and milling in his own shop in North Rocks (near Parramatta) Regards I think that's probably the other way around. Graham sends his cranks to someone in Seven Hills for crack testing and possibly some maching, but wedging of cranks, and any head work he does himself. I'd be very surprised if he sent a head out anywhere unless it was because he was too busy, or if there was something particularly wrong with it that required fixing over and above servicing or performance porting/polishing. KB |
Author: | gafmo [ Fri Nov 21, 2008 12:39 pm ] |
1310/71 wrote: miniDave wrote: I would talk to Graham Russell. (02) 9630 2195 When my engine was done, Graham sent the head to a company in Hornsby. He can do the crankshaft and milling in his own shop in North Rocks (near Parramatta) Regards I think that's probably the other way around. Graham sends his cranks to someone in Seven Hills for crack testing and possibly some maching That would be St George Cranks on Bearing Rd Seven Hills "Spiro" But I Pop into Graham Russells place and have a talk about what you want 113 North Rocks rd North Rocks. Dont expect it to be clean as he is a busy man ![]() I have to get a Ausmini sticker on the pole out the front ![]() |
Author: | drmini in aust [ Fri Nov 21, 2008 12:52 pm ] |
Graham does all the head work himself, unless it needs unleaded seats fitted, ot K-liners fitted in the valve guides. |
Author: | pristic [ Fri Nov 21, 2008 2:18 pm ] |
Yeah, GR for sure. He does the unleaded seats Kev - just doesnt like to ... its the old debate we always had about unleaded seats vs regular... He does send away for K-lines though... and crack testing but pretty much EVERYTHING else is done there. Oh, he sends away for hardening too - ie/ drive shafts, etc etc Johnno - your in Vineyard ay? Im over in Kellyville and there are a few of us around the hills... Cheers, Pete |
Author: | drmini in aust [ Fri Nov 21, 2008 2:21 pm ] |
Pete he sends em out if you want/need unleaded seats, I asked already. Too time consuming to bore accurately on his mill (or mine). There is a special machine made for this job, he doesn't have one but the head joint does. ![]() |
Author: | pristic [ Fri Nov 21, 2008 2:23 pm ] |
Dont disagree with ya often Kev - but I guarantee he was doing unleaded seats last week ![]() Might have been a one off job - maybe they were in a hurry - oh wait - then they wouldnt send to GR would they ![]() Pete |
Author: | drmini in aust [ Fri Nov 21, 2008 2:25 pm ] |
Not saying he can't do it, just that usually they get sent away. We did an inlet seat in my Moke head this year, I bored it here and he fitted it. ![]() |
Author: | pristic [ Fri Nov 21, 2008 2:26 pm ] |
Yeah I know - he was grumbling most of the time too... must have been a one off gig. Who wants unleaded seats anyway ![]() Pete |
Author: | drmini in aust [ Fri Nov 21, 2008 2:34 pm ] |
pristic wrote: Yeah I know - he was grumbling most of the time too... must have been a one off gig.
Who wants unleaded seats anyway ![]() Pete Well when you have already fitted big valves then worn the seats away, inserts and original valves look a great idea. ![]() I'm doing up an ex-race head 940 for my boss at the moment, it had big exhausts in, then it later got inserts fitted and standard ex valves.. Good job, no problems. |
Author: | miniDave [ Fri Nov 21, 2008 3:01 pm ] |
drmini in aust wrote: Graham does all the head work himself, unless it needs unleaded seats fitted, ot K-liners fitted in the valve guides.
Correct - I had unleaded valve seats put in and they went to Hornsby. |
Author: | 9YaTaH [ Fri Nov 21, 2008 6:19 pm ] |
Post subject: | K |
pristic wrote: He does send away for K-lines though...
Where in Hornsby ![]() ![]() |
