It is currently Sun Jul 20, 2025 3:38 am
 Post subject: Door cards
PostPosted: Fri Nov 21, 2008 7:04 pm
OK I want to make 2 new door cards and re-use my 1966 Deluxe vinyl..
But what should I use? :?
I went to Bunnings last Sunday and got a sheet of 3.2mm masonite (looks like what the original was), it's been sitting on the BBQ table under cover all week and it's warped up at the ends already! :cry:
It is whiteboard masonite, all they had in 3.2mm.
I don't want to use MDF (compressed sawdust) in case it gets wet, but I guess I could coat it in fibreglass resin.
Any ideas? Plywood? :lol:
PostPosted: Fri Nov 21, 2008 7:20 pm
I've got new door cards in a non Mini and the upholsterer used +/- 5mm thick ply underneath the upholstery. It's holding up nicely. 8)
PostPosted: Fri Nov 21, 2008 7:51 pm
Marine ply & coat it with something decent before you appolster it
PostPosted: Fri Nov 21, 2008 8:38 pm
Thanks guys.
I have used marine ply for floors in alloy boats, it's pretty stable once well coated with fibreglass resin. Stops it rotting too.
PostPosted: Fri Nov 21, 2008 8:49 pm
The this plastic material i used for my door cards. Being plastic it doesnt rot and does a good job. Forgot what its called but its like 2 sheets of plastic with a zig zag look between the two layers, if that makes sense :?
PostPosted: Fri Nov 21, 2008 9:07 pm
Yeah I've seen that stuff, it's used for packing.
Now, where did I see it- ah yes, at Rheem! :P
4myego, your next mission will be to acquire me some- buddy, pal, maaate.....
PostPosted: Fri Nov 21, 2008 9:39 pm
Real Estate for sale signs are made of that stuff, plenty of them about at the moment :lol:
Cheers Pete
PostPosted: Fri Nov 21, 2008 9:52 pm
That plastic is called corflute.
Don't bother forking out for marine ply, just use cc or cd ply. The only difference between marine ply and structural is m/ply has a thin veneer on the outer layers. Neither is any more water proof then the other.
Personally when i next do my door trims I will be using a product called Forex Classic. It is a high density PVC sheet. Google Halifax Vogel Group and give the nearest branch a call. It might be a bit more expensive but definately one of the better products I have come across. We use it for marine upholstery. You will need a staple gun of some sort as contact adhesives don't hang on to well.
Terry
PostPosted: Fri Nov 21, 2008 10:01 pm
My neighbour restored a wooden boat recently. The exy marine ply over the cabin is delaminating and buckling already and this is despite a very thick layer of paint over it, along it's edges and underneath as well. He's not a happy chappy at the moment.
PostPosted: Fri Nov 21, 2008 10:10 pm
yeah, well,,, that`s obviously because it wasn`t sealed properly
marine ply is really good,,, but it`s still wood & will warp & peel & lift & do all the things that wood does when it gets wet, if it`s not totally sealed like the good doc said,,, resin is probably the best thing to use
PostPosted: Fri Nov 21, 2008 10:21 pm
That material is called Coreflute, and is used for signs and the like.
Can be bought from Cadillac Plastics, or found in front of any house that is for sale with a sign!
 Post subject: old school
PostPosted: Fri Nov 21, 2008 10:35 pm
Old school panels, canvas cut to size and soaked in varnish , while its still wet it can be molded , it goes hard like a rock , and can be painted, drilled and screwed.
PostPosted: Fri Nov 21, 2008 10:46 pm
Yea thats the stuff....got it from bunnings, cheap and doesn't soak water.
PostPosted: Sat Nov 22, 2008 6:49 am
If you are doing a round nose coreflute is too thick and wont fit under the top crome retaining strip. Also be careful when using screw retainers: its easy to collapse under the pressure
When I was at TAFE we were taught to use a thing called Bitumen Board ; its like the original cardboard but is impregnated with bitumen right through the material. Maybe no longer available but Ive used it on a number of cars and its brilliant. Still need to make sure the access holes in the inner door are sealed with plastic. You could try Daleys or Upholstery Distributors at Prospect . UD are the old Cope Musgrove who have been selling materials since the 1920's Both have cash sales at the door
Mk1 Cooper S
Mini K Rally car
PostPosted: Sat Nov 22, 2008 7:38 am
Hey Kev - I used the same stuff as you bought however I sealed it with a wood sealing compund - been sitting in the garage and moved twice in 2 years and still the same as what I bought it - except it is white(the compound goes on really thin so I did 2 coats). It is completely waterproof so will stop the warping when they finally go back into Henry.
Hooroo
Rob Forsyth
Miniot!!
