Flywheel drive straps https://www.ausmini.com/forums/viewtopic.php?f=2&t=47822 |
Author: | Wombat [ Sat Nov 22, 2008 9:50 pm ] |
Post subject: | Flywheel drive straps |
How much can you build these up safely with washers? I have to fill about a third of and inch (0.304") to get them level |
Author: | 9YaTaH [ Sat Nov 22, 2008 10:35 pm ] |
Post subject: | Re: Flywheel drive straps |
Wombat wrote: How much can you build these up safely with washers? I have to fill about a third of and inch (0.304") to get them level
as much as it takes to get em flat....should be built up with weld though ![]() |
Author: | drmini in aust [ Sun Nov 23, 2008 6:09 am ] |
Noooooooooooooooo...!!!!!!!!!!! Make 3 new thick spacers on a lathe...... do it properly. Hole should be 3/8" diameter so they fit snug on the bolts. |
Author: | albino235 [ Sun Nov 23, 2008 2:01 pm ] |
9YaTaH wrote: as much as it takes to get em flat....should be built up with weld though
![]() Welding a cast iron flywheel ![]() ![]() |
Author: | 9YaTaH [ Sun Nov 23, 2008 2:25 pm ] |
albino235 wrote: 9YaTaH wrote: as much as it takes to get em flat....should be built up with weld though ![]() Welding a cast iron flywheel ![]() ![]() Yeah...I must have had a brain fart and was thinking about steel flywheels ![]() |
