Grinding noise
https://www.ausmini.com/forums/viewtopic.php?f=2&t=47897
Author:  Blokeinamoke [ Tue Nov 25, 2008 5:14 pm ]
Post subject:  Grinding noise
I am getting a cylic grinding noise from the lhs rear hub. I can see that the drum is contacting the backing plate - but I cant seem to able to adjust it out either by trying to recentre the hub or bashing the bejesus out of the backing plate so it clears.
The bearings seem fine and the hub is running centred - or as far as I can tell.
Any suggestions?
Author:  mickmini [ Tue Nov 25, 2008 5:42 pm ]
the backing plate has two lips go around the edge of the drum. the outside one that you can see is where you are trying to lever it out. it might be the inside one that is rubbing. take the drum off and look for signs of contact.
michael
Author:  Blokeinamoke [ Tue Nov 25, 2008 5:45 pm ]
done that - the drum is rubbing on one side of the the face of the backing plate - it is ocntacting on the front quarter of the backing plate.
