It is currently Thu Jul 31, 2025 7:49 pm
 Post subject: 2 questions
PostPosted: Tue Nov 25, 2008 7:18 pm
i ve tried to search but cant seen to find what im looking for.
2 questions
1. decided to adjust tappets yesterday and once i had the rocket cover off turned upside down and booyah... milky under there... is that BLOWN HEAD GASKET. :? or crud :lol:
2. I have inconsistent oil pressure. when cold seems ok 50-60 and 40 at idle =500rpm . when hot pressure at about 50,, and as of recent 20-25 at idle... also sometimes stalls when hot and at that pressure when in neutral.------ is this oil pressure ok (in saying that i do know that others have 60 psi consisently). if not could that maybe a result of the above #1 qestion and being blow gasket.
just a little confused
PostPosted: Tue Nov 25, 2008 7:25 pm
1 your idle speed is to low at 500rpm should be between 800-1000, bump it up and it should stop stalling and the oil presure will be higher at that speed
2 cannot tell if it is a blown headgasket, when was the last time you changed the oil and do you do any decent longer trips
Users browsing this forum: Bing [Bot], cruiser23 and 87 guests
