It is currently Sat Aug 09, 2025 1:19 am
PostPosted: Wed Oct 24, 2007 5:55 pm
This space for rent
So I've put an Excel spreadsheet together to calculate road speed vs revs in each gear, and I've got a couple of common gear / diff ratio combinations which I snarfed from the technical data section on minis.com.au. I'm pretty sure though that this is an incomplete and/or incorrect list, so I'm looking for something authoritative.
Can someone point me in the right direction, or quote correct numbers off the top of their head?
Once I get accurate data, I'll put the spreadsheet up on the web somewhere for others to enjoy. I always knew my road speed vs revs in 4th, but it's interesting to compare with other wheel/tyre and diff combinations :)
PostPosted: Wed Oct 24, 2007 6:19 pm
4.33:1 :shock:
4.26:1 (Morris 1100 Australian)
4.133:1 (Morris 1100S 12YD engines, UK Morris 1100)
3.93:1
3.765:1 (Morris 1100S 12Y engines, Mini Deluxe, Mini 850)
3.647:1 (often called 3.65:1, Clubman 1100, K 1100)
3.44:1 (Cooper S and late Aussie production)
3.10:1
2.95:1
2.76:1
Automatics...
3.48:1 (early UK Automatics)
3.27:1 (Morris 1100 Auto, Minimatic)
PostPosted: Wed Oct 24, 2007 7:11 pm
This space for rent
They're all final drive ratios I assume?
What about gearbox ratios? Surely they're not the same in every 'box..?
PostPosted: Wed Oct 24, 2007 7:32 pm
Hey guys;
Do you know what the standard Moke ratio's are?
I've got a standard A+ in mine which has 15 teeth on the pinion and 65 teeth on the crown, primary gear has 30 teeth, not 29. Not sure what that makes it in ratio figures?
Chris
_________________________________________________
1956 Bentley
1969 Morris Cooper S
1975 Citroen DS23 Pallas EFI 5 Speed
1982 Moke Californian 1275
1997 ZZR 1100 D
1989 Ke Laser Ghia-"The Runner"
2006 Holden Vectra CDX v6
PostPosted: Wed Oct 24, 2007 7:48 pm
4th gear is 1:1 no matter what gearbox.
The primary gears are 24/31/24 on the normal box and 29/37/29 with the fine tooth A+ gears.
There is also a 30/37/29 economy gearset as well.
PostPosted: Wed Oct 24, 2007 7:51 pm
CUB wrote:
Hey guys;
Chris
65 divided by 15 = 4.33:1 and the 30 tooth primary gear means you have an economy model Metro engine. :shock:
PostPosted: Wed Oct 24, 2007 8:08 pm
4.33:1 :shock:
3.93:1
3.10:1
2.95:1
2.76:1
Automatics...
What about the 3.2?? :1 , I ran one years ago and it was great , just can't remember the full figure it calculated too though .
PostPosted: Wed Oct 24, 2007 8:19 pm
This space for rent
Sorry, you'll have to excuse my stupidity here. The data I have lists ratios for each gear:
1st - 3.200, 2nd - 1.916, 3rd - 1.357, 4th - 1.000. Can you explain how that relates to 29/37/29 etc. (which I assume are teeth counts)?
PostPosted: Wed Oct 24, 2007 8:28 pm
The 29/37/29 is the teeth count on the primary gears.
PostPosted: Wed Nov 26, 2008 3:53 pm
This space for rent
I'd forgotton all about this, thanks willy for reminding me about it :D
I've updated the spreadsheet with ratios taken from my workshop manual, but I'm sure there are still errors in there. I'd appreciate suggestions, corrections etc. so I can update the spreadsheet for all.
Anyone interested in it can grab it here.
PostPosted: Wed Nov 26, 2008 6:57 pm
Note that the drop gears in all automatics are not 1:1.
So, the automatic's 3.26:1 diff ratio becomes 3.76:1, in 4th gear.
No, these 3.26 diff gears will not fit in a manual... if you were wondering. It's too big... :cry:
 Post subject: Gearbox abd diff ratios.
PostPosted: Wed Nov 26, 2008 7:52 pm
I remember Years ago (over 20) I was given a good list of gears versus diffs versus speeds by our great Friend Jack Read. It helped me work out the best Diff ratio to use for speedway. Perhaps Matt the Miniman can help you here. Jack faxed me a whole sperad sheet but un fortunately today the paper has gone blank thanks to old fax paper. I am sure Jack will have this in his computer still.
"Let us remove your "SHORTS"
PostPosted: Wed Nov 26, 2008 7:59 pm
This space for rent
Thanks Doc, the auto was a late addition as I saw it in the workshop manual at the last minute. Didn't notice the drop gear ratio.
Anything else obviously wrong with the ratios?
PostPosted: Wed Nov 26, 2008 10:29 pm
Revs per 100km/60mile would be good to
EG 3.44 - 4000rpm/100km (thats close enough for me :lol: i think it is like 3900 or so somebody will correct me if im wrong)
I think i have this info in an old tuning book i will have a look tomorrow
Brenton
PostPosted: Wed Nov 26, 2008 11:27 pm
Used in 63HP SPI injection-Coopers (at least in Europe).
Pt. N° - Crown - / Pt. N° - pinion - Ratio
DAM6327 59 DAM6243 DAM2808 19 3.105
DAM2806 61 DAM2807 DAM2808 19 3.211
3,21:1 uses the same pinion as the 3,1:1.
Going to use that too.
sounds a good compromise between 3,1 (slithly too long) and 3,44 (slightly too short) - for my taste at least :)
