It is currently Sat Jul 19, 2025 9:45 am
PostPosted: Mon Jan 05, 2009 3:46 pm
Arrgh, this is doing my head in, have just repalced leads, coil and spark plugs. have done the old bush thumb compression test and have put the leads upto the rocker to check spark all ok but still nothing. Take the leads off them no difference in power loss.
What else can i check, can you check the timing on two and three?? Sorry n00bie questions i'm sure.
PostPosted: Mon Jan 05, 2009 3:50 pm
Can you borrow another distributer cap and try that ? Since you've replaced the leads coil and plugs it's the only other bit that could cause two plugs to not fire . Could also be a worn distributor shaft though but unlikely as the cam lobes for 2 and 3 are on opposite sides from each other .
PostPosted: Mon Jan 05, 2009 4:02 pm
i've ordered a new one with rotor button should get it tomorrow, that's if minisport are open
PostPosted: Mon Jan 05, 2009 4:14 pm
High heel ninja
If your in Sydney why are you ordering parts from SA?
Doogie
PostPosted: Mon Jan 05, 2009 4:21 pm
since classic motoring is shut till they move i don't know anyone else?? Who else can i get parts from?
Bearing in mind i'm lazy and hate having to use a phone. I should have probably rang minispares or karkraft but I love the net and i'm a n00b.
PostPosted: Mon Jan 05, 2009 4:23 pm
ginger ninja
ginger ninja
use the phone and call Mini King at Narellan (south west sydney). Mini King are great for parts and advice (sorry dont have their number with me)
sports850 wrote:
PostPosted: Mon Jan 05, 2009 4:26 pm
Have a look through here , http://www.ausmini.com/forums/viewtopic.php?t=10543 So classic motoring is gone now ?
PostPosted: Mon Jan 05, 2009 4:27 pm
classic motoring are just moving
PostPosted: Mon Jan 05, 2009 6:04 pm
Yep they told me as well, but didn't say where to... :?
PostPosted: Mon Jan 05, 2009 6:09 pm
They are moving to Melbourne :D
PostPosted: Mon Jan 05, 2009 6:24 pm
Grrrrrrrrrrreat..... :roll:
So where are y'all near Can-Bra going to get your daily Mini fix now..?
PostPosted: Mon Jan 26, 2009 7:10 pm
The Mini King
Mini King, Its Just up the Road a little :wink: :)
PostPosted: Mon Jan 26, 2009 7:13 pm
:mrgreen: :mrgreen: :mrgreen:
PostPosted: Mon Jan 26, 2009 7:39 pm
have you got firing order right. ie have you crossed 2&3 over. eng will still run but no power
www.minisprintgt.com
PostPosted: Mon Jan 26, 2009 7:50 pm
That was the problem, he had 2 and 3 the wrong way, but he had to start another couple of threads before he go it running. :wink:
