It is currently Thu Jul 31, 2025 7:49 pm
 Post subject: GT flare base template?
PostPosted: Thu Nov 27, 2008 5:48 pm
Hey
did a search first, dont worry!
after a template for the basic mini clubman flare metal base thing, (the flares rivet to)
Im getting rid of those horrid screw on ones, thank god.
so yeah, I need to make up some bases, or buy some, what ever is easiest!
PostPosted: Thu Nov 27, 2008 7:18 pm
just make some, or arm yourself with an empty cereal box and go find a clubman S
PostPosted: Thu Nov 27, 2008 8:17 pm
The flares are available from MinisPlus if my memory serves me correctly. Contact Lindsay at [email protected] and he should be able to confirm,
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu Nov 27, 2008 8:49 pm
PM sent
PostPosted: Fri Nov 28, 2008 6:32 am
Mini King also has them.
PostPosted: Fri Nov 28, 2008 7:23 am
If you buy some panel steel and cut it into 4 rectangles long enough to run aronnd the underside of each wheel arch and wide enough to come out further than where the flare would sit.
Spot weld the steel in place and sit the flare in position and trace around the edge so you can trim the steel to suit the flare.
This will give a factory look.
Users browsing this forum: Bing [Bot], cruiser23 and 86 guests
