It is currently Tue Aug 12, 2025 2:40 am
PostPosted: Fri Aug 14, 2009 6:38 pm
hey guys just wondering how hard it would be to fit a new speedo and tacho into my '62 850. will be fitting them so they can be removed if i sell it.
also what is a good brand of guages that is resonably priced.
PostPosted: Fri Aug 14, 2009 6:44 pm
Supercharged
smiths
and they look period also which is the only thing i'd do with a '62 850 :D
you could use a speedometer from an mg or austin healey
PostPosted: Fri Aug 14, 2009 9:51 pm
I love these...
there AUTOMETER OLD TYME WHITE II 5" QUAD GAUGE & TACH/SPEEDO
right up from ebay listing..
Size:
KIT, 5" (127mm)
Type:
In-Dash Tachs & Speedos
Range:
8000RPM/120 MPH/100 PSI/100-250 deg.
F/8-18 Volts/240ΩE-33ΩF
Notes:
Operates on 4, 6, or 8 cylinder engines
with points, electronic, and most 12V
high performance racing ignitions.
Includes all gauges senders, including
7/8-18 speedometer sender.
Resettable Trip odometer.
Will work with most factory sensors.
If sender may be required, see model
5291 or 5292 in Accessories Section.
Features Vintage-Style Domed Lens
i think the look the duck nuts...
price is just under $600 aus..
not bad considering you are getting spedeo....rev gauge...plus fuel water volts and oil..
PostPosted: Fri Aug 14, 2009 11:43 pm
Forum Graffiti
Check these out...
>>>Lotsa Gauges!<<<
Users browsing this forum: Bing [Bot] and 241 guests
