Acid smell
https://www.ausmini.com/forums/viewtopic.php?f=2&t=48434
Page 1 of 2
Author:  mollymoke [ Sun Dec 14, 2008 7:48 pm ]
Post subject:  Acid smell
Hey all,
My 69 van has the battery behind the drivers seat. I have recently noticed a strong (like takes my breath away!) acid smell in the car some times, I expect it may be the battery, but on inspection there are no leak marks, or acid build up on the terminals.
Alternator seems to charge up fine (cranks over fast every time) some times I only start it once a week and the battery is stilll ok.
Any ideas? I guess I should get the battery tested and charging volts/amps checked.
Author:  drmini in aust [ Sun Dec 14, 2008 8:11 pm ]
This usually only happens when the alternator is overcharging (volts too high). Get it checked before you start blowing bulbs etc.
Author:  John Smidt [ Sun Dec 14, 2008 8:20 pm ]
And If you are going to disconnect the battery (possibility of sparks ) make sure you leave the doors open for a while to allow the gasses ( hydrogen ) to escape
Author:  simon k [ Sun Dec 14, 2008 8:27 pm ]
you might notice the battery is bulging at the sides as well - the gas coming out of the battery is HIGHLY EXPLOSIVE
testing is easy, attach a multimeter from the fuse box to any earth point with the engine running - probably putting out around 17 volts
Author:  mollymoke [ Mon Dec 15, 2008 6:11 am ]
Post subject:  Battery
Thanks for the advice guys, I have always been a bit wary of car batteries, a friend lost an eye while disconnecting the charger (and he was the local servo mechanic!).
So doors open, wait for the smell to go before disconnecting, then testing the current, I have 'felt' the battery and it does not seem to heat up (like small rechargables that I use) when it is charging.
Cheerio,
Author:  Flute [ Mon Dec 15, 2008 8:36 am ]
Is this because of a faulty voltage regulator? (I'm just learning)
Author:  simon k [ Mon Dec 15, 2008 9:14 am ]
yep - I had one go a few years ago - smells of sulphur
molly, I'd go to an auto elec if I was you.... actually, I was you, and I did go to an auto elec. Local guy who did his apprenticeship on Lucas stuff
Author:  mollymoke [ Sat Dec 20, 2008 2:54 pm ]
Post subject:  Alternator regulator
Well I took the alternator to a local auto electrician, quick 24 hour turn around, and yes the regulator was shot, otherwise in good nick (it is only 4 years old or so), regulator just gave up.
But then, he charged me $220.00 for the work, $75.00 for parts and the rest for his labour, checked it all out stripped and cleaned while he was there.
So I ask myself, what is the cost of a change over unit (actually I don't want to know now!), I guess at least I gave a local some work, and reused (as opposed to dump and buy new one) rather than create more land fill!
Just feel a bit ripped off right now, but I'm sure I'll feel better when it's back in the car and no smelly hot battery!
Cheers for your advice!
Author:  IndigoBlueCooperS [ Sat Dec 20, 2008 4:07 pm ]
Molly,
Bad choice having it repaired.
The local guy we use had new, Lucus ones. A couple of years ago, one cost $165. Still going strong in the wifes car. It is a 16 or 18ACR. Bolts strainght on with internal regulator.
Author:  Ziegech [ Mon Dec 22, 2008 2:47 pm ]
i had this issue aswell but it took me agaes to realise because i alwasys played music which countered it :oops: all fixed now
Author:  Wombat [ Mon Dec 22, 2008 3:52 pm ]
I bought a full overhaul kit from a UK eBay trader for $33 shipped. Had regulator, slip rings, brushes, diodes, plastic end cover, and instructions.
Author:  Davo111 [ Mon Dec 22, 2008 3:56 pm ]
loud music counter acts the acid smell, amazing scientific experiment. Must have been playing ACID ROCK....
:wink: :wink: :wink: :wink: :wink: I just had to sorry.
Author:  jess [ Mon Dec 22, 2008 4:10 pm ]
Convertible Mini (Tony) sells alternators for minis at a very reasonable price.
Author:  Wombat [ Mon Dec 22, 2008 4:14 pm ]
I've got one on my shopping list - $165 for 65 amp output
Author:  jess [ Mon Dec 22, 2008 4:16 pm ]
me too! I would love one, I have only heard great things about them and he & his wife are lovely people too
