It is currently Sat Jul 19, 2025 9:56 pm
 Post subject: Rear S drums
PostPosted: Wed Feb 16, 2005 6:06 pm
i have some new rear S Drums with the 1 inch step on them i was just wondering if anyone has any tips on fitting them. i know i need longer studs and set screws. does anyone have any tips on knockin the studs out. i'm Fiiting them because i have discs and i need to even out the front and rear track.
PostPosted: Wed Feb 16, 2005 6:14 pm
I sit the flange on the vice, hit stud with BFH... 8)
You can fit the new ones the same way (oil them first) or press them in with a press, or use the vice and a couple of sockets. :wink:
Or, wind a wheel nut on the stud, with some washers underneath it.
Users browsing this forum: 748rum, Phil 850 and 94 guests
