It is currently Sat Jul 19, 2025 3:01 am
 Post subject: Dyno Day new Needle
PostPosted: Sun Feb 27, 2005 7:48 am
Okay I did the Dyno Day yesturday and we got 45.2..But its running rich low down and lean up top....Bugger ay but atleast I know
I have tried WinSU152 but they dont have out 1098 +20/40/60 and of course they dont have the RE13 cam...I know the cam is close to .290 but which manifacture should I use for winsu
Otherwise anyone in the know..what needle should I use....1098 +60 RE13 (290) cam a little shaved off the head LCB (perry) HIF44 Needle EDP
I need Leaner down low and and richer up top
PostPosted: Sun Feb 27, 2005 11:23 am
G'Day Gafmo,
You will need to pull the needle out from your carby and get the code number stamped on it. I have the SU needle book with all the profiles and code numbers, but I have found that these days, not that many of them are available. Alternative would be to machine your own or modify an existing one.
Dino
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Sun Feb 27, 2005 11:53 am
Are you sure it's an EDP needle? It's not on the list in winSU
PostPosted: Sun Feb 27, 2005 8:51 pm
Funny you sould say that Scott...I also tried WinSU152 first proir to asking starting this thread.. :wink: it came up with does not reconise Needle :? Arrrr its a Pommy site and it was tuned by a local..Keven Klyning in Syd...So maybe an Ozzy modify..I don't know so I just asked the question..But I did try it out very ruffly on winSu, 1098 no mention of +20/40/60 REcam so I just tried a 285 cam and it cam up with BDP or try BBZ, BDK.
I have also ask this question in another forum :shock: Very Very Sorry :oops: but some one came up with thier is no such needle :shock: it may be worn and could be a BDR..Ill have to recheck tomorrow morning.
I just cant see how it can wear in thier :?:
I'll recheck and refer :wink:
Cheers Guys
PostPosted: Sun Feb 27, 2005 11:48 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i think my 44 had a bbz in it hey phildo what needle was in the carby ??
makka
PostPosted: Mon Feb 28, 2005 5:58 am
OK I'll hijack this thread right here.. :wink:
what needles should I run in Barney- twin HS4s on a 1293, with Ramflo filters & an RE-13 (similar to 276/286) cam? :shock:
Any ideas? It's been 35 years since I ran twin HS4s... :?
/end hijack... 8)
PostPosted: Mon Feb 28, 2005 10:05 am
Hi Kev,
check with chris because the twin HS4's i sold him were off dads old 1293 "S" but i cant remember what they were, he may remember the codes.
100% Pure A Series Turbo
PostPosted: Mon Feb 28, 2005 11:54 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
1 1/4 run bdl's if that is any help :)
makka
 Post subject: Vizard
PostPosted: Mon Feb 28, 2005 12:08 pm
/end hijack... 8)
Step 1...consult Vizard??...to get you in the ballpark
Step 2....dyno to optimise..
Step 3....road test to confirm dyno outcome???
:lol:
PostPosted: Mon Feb 28, 2005 8:17 pm
Yeah Vizard sez RED springs, with #3 or #4 needles... :?
I think step 3 comes before step 2, Mick.. unless you work for lotsa $$$, which I don't.. :lol:
OTOH the dyno guy might have a tin full of needles to try, and only charge me for the last pair.. :wink:
 Post subject: Ouch
PostPosted: Mon Feb 28, 2005 10:07 pm
Well if they come that caper they probably aint too Mini friendly and you should get outta there :?:
Hmmmmm, lots of road testing without the benefit of a sensor up its clacker etc etc ...just my 5c :D
PostPosted: Mon Feb 28, 2005 10:12 pm
:idea: Maybe I should build a fuel/air ratio meter, then who needs a dyno for needle selection. :wink:
I'm just intimidated by the cost of needles, x2, and the selection of 800? to choose from. :?
And people wonder why I prefer tuning Dellortos etc.. :lol:
PostPosted: Mon Feb 28, 2005 10:14 pm
Yeah SU's are bastards of things.
Once you get the right needle, then set them up just right, you have to do it again in a month coz its gone out of adjustments!
SU carbs and Mini drum brakes - the two worst things the English have come out with :lol:
PostPosted: Mon Feb 28, 2005 10:30 pm
Oi! Don't knock the drum brakes! :wink: :lol: I agree about SU needles though LOL
PostPosted: Tue Mar 01, 2005 11:11 am
G'Day,
Don't know what you guy's are going on about SU carby's... I had my twin SU's properly re-built and GR set up the needles while running in the engine on his dyno, have not touched them in 5 years except to top up the oil, and clean the filters. With working chokes, mine start first kick summer or winter...
Dino
Users browsing this forum: No registered users and 112 guests
