replaced coil now no spark
https://www.ausmini.com/forums/viewtopic.php?f=2&t=48639
Author:  deg [ Mon Dec 22, 2008 8:38 pm ]
Post subject:  replaced coil now no spark
worked yesterday and replaced with a new replacement Bosch SU12, what the hell. :twisted:
Author:  Lockie91 [ Mon Dec 22, 2008 8:59 pm ]
could be the contact set, could need replacing. they are worth $25
Author:  simon k [ Mon Dec 22, 2008 10:02 pm ]
it's possible to get a new one that is dead...
if the old one was working, put it back on, if it wasn't working, then find one that you KNOW does work
put everything back exactly how it was, make sure the car starts, then return the faulty coil - unless you find the problem elsewhere with a loose fitting/missing step/etc. which is often the case
Author:  deg [ Mon Dec 22, 2008 10:06 pm ]
it worked yesterday but while it was jumping across the negative i would push the lead down and loose power and i would also get a small charge at the back of the carby while trying to tune it. ???
Author:  deg [ Mon Dec 22, 2008 10:08 pm ]
what would be the standard resistance you would expect from a 12v??
Author:  Fat Boy Dave [ Mon Dec 22, 2008 10:40 pm ]
I had something like that with my Rover, turned out it was a short on one of the wires running off the coil that had rubbed all the sheathing off. Took me a while to find. Stoopid Lucas. :roll:
Author:  drmini in aust [ Tue Dec 23, 2008 5:45 am ]
a 12V coil is about 3 ohm. eg Bosch SU12 or GT40.
a coil that uses a ballast resistor (or the pink resistor wire on UK Minis) is about 1.5 ohm. eg Bosch GT40-R.
Author:  simon k [ Tue Dec 23, 2008 9:54 am ]
GRRRRRRRR!!!!!!!!!
what's that got to do with 'Stoopid Lucas' ????
stupid owner, stupid previous owner - stupid whoever neglected to put the wire in it's proper place to stop it from rubbing on something - Lucas didn't fail to maintain the car
I hate it when people bash Lucas electrics - I wish I could build an electrical system that survives 40+ years of neglect, shoddy modifications and ham fisted owners
sorry - raw nerve
Author:  deg [ Tue Dec 23, 2008 10:55 am ]
how can you check the cables using a autometer :?:
