It is currently Wed Aug 13, 2025 2:30 pm
PostPosted: Fri Dec 26, 2008 7:57 pm
Milatsmadmini
any ideas? it looks to be pretty well set onto the head, and im really needing to change the thermostat in it at the moment but am having chance in buckleys trying to get the damn thing off!
any ideas would be most welcome...
PostPosted: Fri Dec 26, 2008 8:00 pm
an idea if you cant get it off with your hands would be a flat nose screw driver carefully id say once you break the seal that first bit the rest should come off by hand....thats what i would do any way.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Dec 26, 2008 8:07 pm
The alloy thermostat housing and the steel studs do not like each other. :lol:
The resulting corrosion can lock the housing to the studs. When this happens they can be almost impossible to get off without braking the housing or the studs (or both) I have had this happen.
Lots of WD40 (or better) and maybe a bit of heat.
Be carefull and have spare parts on standby.
PostPosted: Fri Dec 26, 2008 8:10 pm
2 rules of diy mechanics.
rule 1, if it doesn't move and should use wd40.
rule 2, if it does move and shouldn't use duct tape.
PostPosted: Fri Dec 26, 2008 8:18 pm
rule 3- if all else fails use anglegrinder, cut vertically, next to studs. Fit new housing, they are cheap.
I use 3 Unbrako bolts now not studs, when you undo them any corrosion gets broken away.
I dip the bolt threads in #3 gasket cement, it stops them rusting. Old outboard mechanics trick. :wink:
PostPosted: Fri Dec 26, 2008 8:25 pm
take the Studs out. Double Nut them and lock them together and remove each stud and you should have no troubles :wink:
PostPosted: Fri Dec 26, 2008 8:33 pm
As the Doc said, angle grinder + BFH
If it was that corroded you should be replacing it anyway
PostPosted: Fri Dec 26, 2008 8:45 pm
well what i would do is grab a hammer and smack it fair in the middl so it splits then from there on smooth sailing but only do that as a last resort try spliting from the head with a screwdriver or a cold chisel if u have one :roll:
PostPosted: Fri Dec 26, 2008 8:54 pm
If you do try to get it off in one piece, don't be afraid of tightening it a wee bit to break the seal. You can go backwards and forwards, each time loosening it off a little bit further as you go.
Hope that all made sense. That's what the mechanic did on another car of mine. The bolt had been in the alloy water pump housing for 34 years before we came along and decided we wanted it out. Nothing was broken in the process, but it did take quite a bit of time and a lot of patience to get it out.
PostPosted: Fri Dec 26, 2008 9:54 pm
what kinda bit are you using there awdmoke?
blokeinamoke wrote:
PostPosted: Fri Dec 26, 2008 10:13 pm
Tungsten carbide tipped alloy blade. Great for cutting alloy bar & sections.
Not really necessary for that kind of hack job, but makes fast work of it.
PostPosted: Sat Dec 27, 2008 2:00 am
bfh i say 8) show that sucker whos boss!
PostPosted: Sat Dec 27, 2008 6:37 am
I had a slight corrosion problem on mine :roll: just needed lots of wd40, hammer, screw driver and a lot of patients
 Post subject: Stop! :-)
PostPosted: Sat Dec 27, 2008 9:31 am
The last thing we need is another patient!! :shock:
The patient application of WD40 and some gentle tapping around the side of the thermo housing with (say) a brass drift usually frees up the stud and corrosions grip on the housing.
PostPosted: Sat Dec 27, 2008 10:19 am
Try using laundry "Preen", it unsticks things like nothing else. :D
Users browsing this forum: No registered users and 181 guests
