Whats ur Idle Oil Pressure?? just for curiosity
https://www.ausmini.com/forums/viewtopic.php?f=2&t=48738
Author:  leema [ Sat Dec 27, 2008 9:14 pm ]
Post subject:  Whats ur Idle Oil Pressure?? just for curiosity
as title says... im gettn about 25psi with super thick oil at about 1100rpm
chuzz,
Matt
Author:  Morris 1100 [ Sat Dec 27, 2008 9:17 pm ]
The light stays off, that's all that matters. :mrgreen:
I think it would be a 2-5psi switch on the light, so the the pressure is somewhere above that.
Author:  drmini in aust [ Sat Dec 27, 2008 9:20 pm ]
Mine is over 30 hot, usually around 40psi unless I've done a fast run.
BUT- I'm running a 9/16" ball bearing in there, not the original valve. The original valves leak oil at idle because they never seat properly, and this drops the pressure. The ball seals much better.
There is a thread here somewhere on how to do it. :wink:
Author:  Mick [ Sat Dec 27, 2008 9:38 pm ]
I'm getting better than 70 psi at idle :shock:(can I haver a new poll option then?) ....but the engine has less than 1/2 an hour on it from new, I fancy it will reduce to a more reasonable level in an hour or so...
Author:  matt van'74 [ Sat Dec 27, 2008 10:03 pm ]
When hot I have 50psi of Oil Pressure at idle.
Matt
Author:  simon k [ Sat Dec 27, 2008 10:47 pm ]
there's no option for more than 40 ....
Author:  Kennomini [ Sat Dec 27, 2008 11:06 pm ]
I idle at 40psi and driving is around 60psi.
Is this why sometimes at idle my pressure wavers from 35-40psi :?:
Author:  gafmo [ Sun Dec 28, 2008 6:41 am ]
normaly around 50 here as I have the 9/6th ball also
If it drops below while driveing I check the oil level :wink:
Author:  leema [ Sun Dec 28, 2008 10:38 am ]
i think the reason why my oil pressure is alittle low is the spacer between the block and oil pump (being an auto) may be leaking. is there any way to prevent this from happening?
My bad about the no 40psi or more option i wrote it but mayy have forgotten to add it..
sorry guys
Author:  drmini in aust [ Sun Dec 28, 2008 11:09 am ]
Use a gasket behind the spacer, put Loctite 515 or 518 on the gasket and outside of the spacer,IF it's an auto 1275 block converted to manual.
If it's on an auto box still, there is no spacer.
Anyway anything over 15psi is plenty at idle.. as long as it has 50+ when revving it's OK, don't sweat it. :wink:
Author:  leema [ Sun Dec 28, 2008 11:24 am ]
yes it is converted to Manual.
Author:  brett [ Sun Dec 28, 2008 3:20 pm ]
mine sits at 50psi at idel and
75 psi at speed
Author:  superSeven [ Mon Dec 29, 2008 4:08 pm ]
just connected up my oil pressure gauge (another excuse to take it for a drive :twisted: )
when hot..
idle: 50 psi
@revs: 75 psi
Author:  david rosenthal [ Tue Dec 30, 2008 11:17 am ]
The seat cut in the block and on the relief v/v poppet are very wide and do not seal well. I have a reamer that recuts the seat in block and I make a new v/v poppet with machined seat to fit block. The poppet is longer and a better sliding fit. Instead of having O.D full length, I machine a undercut to reduce the poppet from sticking in block.
Also check that the hole that dumps the oil when v/v is open does not have sharp edge on it and that the dump hole behind spring is clear.
Check that the spring is not bending under compression[check for wear marks on side of spring] and jambing in block.
When I changed to Honda head using standard mini pump and relief v/v the pressure went to 80-100 lbs at idle[closer tolerances in head and no cam in block] and I used a ball instead of poppet. The ball pushed back and jambed in dump hole, so replaced it with better working full flow assembly. The spring has been changed [different spring rate]and the relief v/v spring has been set-up with a adjusting screw instead of plug.
I now have idle pressure at 50lbs and full revs at 80lbs hot or cold. This can be adjusted easily if there is any pressure drop from pump delivery.
I wish I had done this on the last eng as the relief v/v sticking caused the cylinder head valve to hydraulic, exit the exhaust and stuffed the eng.
Author:  Lillee [ Tue Dec 30, 2008 7:36 pm ]
50 psi hot idle
