It is currently Sat Aug 16, 2025 11:16 pm
 Post subject: Rpm drop & head gasket Q
PostPosted: Sat Dec 27, 2008 11:01 pm
When i pull each lead off the engine the first cyl makes a big difference and the rpm drops a fair bit but on number four when i pull the lead off it doesnt make much diference. why is this?, ive swaped plugs and leads between the two but its still the same outcome.
How can i diaognose/what are the signs of a blown head gasket other than oil in the water & water in the oil?
thanks :wink:
PostPosted: Sat Dec 27, 2008 11:08 pm
Can't explain the rev drop but your other question about diagnosis. A compression check on each cylinder can in some circumstances help diagnose a headgasket issue (particularly if you had a benchmark previously which suggested they were similar to begin with).
KB
PostPosted: Sun Dec 28, 2008 5:57 am
1&4 should drop the same rpm, but if motor has a big cam in you will probably find 2&3 have less rpm drop than 1&4.
Blame the siamesed inlet ports I think... :lol:
If 1&4 are different it could be a leaky valve, or worn rings, in one cylinder. Not always a head gasket.... :wink:
PostPosted: Sun Dec 28, 2008 7:59 am
Location: in the shed cutting, grinding and painting my shit
number 1 cylinder will always have a bigger effect than the rest.
this is because the engine is timed to number 1, and the other cylinders "follow" along.
every engine has a certain amount of tolerance (+ or -), this goes for the crank journal timing in relation to each other, they can be (and usually are) a few degrees out.
rod lengths can vary, affecting compression ratios in each cylinder.
even the cam lobes are not always perfect.
unless you have "blue-printed" your engine there will be differences in how each cylinder works, its a compromise.
Matt68 wrote:
I'd like to believe in Karma, however, sometimes I firmly believe we should become the instruments of Karma.
PostPosted: Sun Dec 28, 2008 8:18 am
Go buy a compression gauge - they are cheap enough. I check my cylinder pressures at every oil change and write them down.
Daniel
Users browsing this forum: No registered users and 344 guests
