clutch thread size https://www.ausmini.com/forums/viewtopic.php?f=2&t=48763 |
Author: | Beanie [ Mon Dec 29, 2008 9:39 am ] |
Post subject: | clutch thread size |
O.k. probably been asked a few times before but i just wanted to know the tread size and pitch on a VERTO flywheel can't seem to find anything that wants to fit nicely in there 3/8 unc wobbles around like nothing .. so if you could help out that would be great thanks Beanie ![]() |
Author: | simon k [ Mon Dec 29, 2008 10:00 am ] |
definitely wouldn't be UNC, as UNC is normally only used in the alloy housings - you've obviously tried a 3/8 UNF like a normal flywheel? which bit are you trying to find a bolt for anyway? I've never seen how a verto flywheel holds together, want to put up some pictures? and I doubt that ones been asked before! |
Author: | drmini in aust [ Mon Dec 29, 2008 10:28 am ] |
M10x1.5 used on puller bolts for Verto. ![]() |
