It is currently Mon Aug 04, 2025 1:31 am
PostPosted: Tue Dec 30, 2008 11:53 am
Have been having a misfire problem of late as well as many others anyway finally got it going and put the colortune on three and it's not firing properly, have just replaced coil and leads??
PostPosted: Tue Dec 30, 2008 1:09 pm
Theres your answer...try one of the old leads on three :idea:
PostPosted: Tue Dec 30, 2008 2:16 pm
tried that still no luck, have just also discovered 2 has dropped also.
PostPosted: Tue Dec 30, 2008 2:54 pm
start with distributor cap, then look to see if gap is same on all lobes ( bent shaft)
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Tue Dec 30, 2008 3:28 pm
dead plug?
checked the compression?
PostPosted: Tue Dec 30, 2008 3:57 pm
i have only noticed that there appears to be no spark when using the colortune?
PostPosted: Tue Dec 30, 2008 4:06 pm
so it's not the lead or the plug - have you put a known good plug in the lead and held it near the rocker cover to see if it sparks?
if there's spark there, it might have lost compression due to a blown head gasket or a burnt valve, but you've gotta check everything you can possibly think of checking to narrow it down....
PostPosted: Wed Dec 31, 2008 10:31 am
thanks i'll try that this morning
