Bolt stuck https://www.ausmini.com/forums/viewtopic.php?f=2&t=48794 |
Author: | madarsemini [ Tue Dec 30, 2008 5:08 pm ] |
Post subject: | Bolt stuck |
I have a bolt stuck flush and can't remove it With pliers as it is flush. Whats the tools called to remove it? I forgot the name. Any help would be much appreciated. |
Author: | doogie [ Tue Dec 30, 2008 5:10 pm ] |
I think the item you are thinking of is called a ezy out. Doogie |
Author: | Morris 1100 [ Tue Dec 30, 2008 5:35 pm ] |
Screw extractor and easy out are the same thing. Be carefull, they are usually rubbish. You may do a better job without them. |
Author: | 9YaTaH [ Tue Dec 30, 2008 5:49 pm ] |
Post subject: | Centre Pop? |
Depending on where the bolt is....you may be able to centre punch (using a very sharp point), dead centre as a guide for a a sharp drill bit....just big enough to leave the threads behind....then pick them out with a suitable tool (a scriber is usually good). |
Author: | drmini in aust [ Tue Dec 30, 2008 6:11 pm ] |
Forget ezy-outs- if stud is broken off flush because it's jammed or rusted, you have a 50/50 chance of breaking the ezy-out in there, and they are hardened so you just made the job a lot `harder' (pun intended). On bolts or studs that are flush, I drill them on centre to the tapping drill size and screw the right size tap in. When you undo the tap it winds the remains of the stud out. Pretty easy job on Minis as everything is cast iron, outboard motors (alloy and S/S bolts) are trickier, that's where I learned to do it properly. ![]() |
Author: | Hanra [ Tue Dec 30, 2008 6:43 pm ] |
Yup, i snapped a manifold bolt in the Cylinder head of my old Crummodore. Drilled it out and stuck and easy out into it, then snapped the easy out off flush inside the bolt... Had to drill the ezy out out, then drill the bolt out... |
Author: | gafmo [ Tue Dec 30, 2008 6:58 pm ] |
Once again dependent where it is you can cut a slot in it with a 1mm grinding disk and use a screw driver to get it out |
