It is currently Mon Aug 04, 2025 4:10 am
 Post subject: What's this head?
PostPosted: Tue Dec 30, 2008 11:12 pm
Picked it up with a couple of minis but it's got me stumped :?
Why dose it have those pipes going in to the head, I assume it's into the water jacket.
Small looking valves but I can only find numbers behind the thermo housing and under the rocker cover near cyl 4 bypass hose.
anyone got any ideas and how to I tell what it's off :?:
PostPosted: Tue Dec 30, 2008 11:21 pm
Those pipes are part of the air injection system that was part of the emissions control on late clubmans ... 77 / 78
PostPosted: Tue Dec 30, 2008 11:24 pm
The Mini King
It is off A Mini that was originally fitted with pollution control equipment, You can put some Grub screws in these holes, This is NOT suitable for a 1275
PostPosted: Wed Dec 31, 2008 12:03 am
So those pipes go into the air ports? is that the inlet or exhaust?
PostPosted: Wed Dec 31, 2008 5:49 am
They go into the exhaust ports.
If you want to plug the holes in the head the thread is 7/16" UNF.
Grubscrews this size are expensive in most places.
A cheap way to do it is screw old seatbelt bolts in and cut them off flush.
Or make them grubscrews, by cutting their threads to length and putting a slot in with a hacksaw.
:wink:
