It is currently Fri Aug 01, 2025 11:25 pm
 Post subject: what do u think
PostPosted: Wed Dec 31, 2008 8:33 am
hey guys my car has been sitting in the drive way and were i got it from for about 2 years i figure that is how long it has been sitting there so me and my brother justin who did most of the work started it and it is blowing a lot of blue smoke what do use think ?????? needs a good run or needs new rings it is a 998cc motor
PostPosted: Wed Dec 31, 2008 8:43 am
High heel ninja
If its been sitting for as long as you say it has, the rings have probably bonded to the pistons, normal for a A series engine, run the engine for a couple of hours the rings may unfrezze then selves from the pistons, giving it a oil change wouldn't hurt either.
Doogie
PostPosted: Wed Dec 31, 2008 9:27 am
The TIG
I'd try replacing the valve seals as well. When I got my Traveller it had been sitting for years and it smoked like a b@$t@rd. I had some valve seals so I threw them on and smoking cleared right up. Worth a shot pretty cheap and easy.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Wed Dec 31, 2008 9:53 am
I rescued my MiniMatic from a garden where it had sat for 8 years.
After I got it going and gave it an oilchange or 2 it was fine, and used hardly any oil. :D
PostPosted: Wed Dec 31, 2008 7:11 pm
ok thanks will have to do when i get the chance thanks guys
PostPosted: Wed Dec 31, 2008 8:40 pm
I suppose one solution is drive the bleeding thing and not let it sit there all sad and neglected for so long. Even if you just start it once in a while and show some attention would be a nice idea methinx.
