leaky fuel cap https://www.ausmini.com/forums/viewtopic.php?f=2&t=48819 |
Author: | phillz [ Wed Dec 31, 2008 9:01 pm ] |
Post subject: | leaky fuel cap |
One of my fuel caps leak so do I just replace the cork gasket or the whole cap. If just the gasket how thick do they start out and is just plain gasket cork ? |
Author: | 9YaTaH [ Thu Jan 01, 2009 8:26 am ] |
Post subject: | Re: leaky fuel cap |
phillz wrote: One of my fuel caps leak so do I just replace the cork gasket or the whole cap. If just the gasket how thick do they start out and is just plain gasket cork ?
A rubber sheet impervious to fuel is better....try and get a thickness that will give you a good seal. |
Author: | drmini in aust [ Thu Jan 01, 2009 9:52 am ] |
Go to a boat parts place like Bias Boating or Whitworths, a neoprene rubber seal for a cruisetank is a perfect fit. ![]() Cork gaskets get torn up if there are any burrs at all on your filler neck. ![]() |
Author: | phillz [ Thu Jan 01, 2009 12:02 pm ] |
Thanks guys ![]() |
Author: | simon k [ Thu Jan 01, 2009 12:18 pm ] |
I tried all sorts of different seals, and eventually gave up and I now have a pair of cheapie brand ones that don't leak a bit - first time ever I can fill the tanks right to the neck without losing any! might have to check out a boat shop when I do my resto Kev ![]() |
