It is currently Mon Jun 23, 2025 7:02 pm
PostPosted: Sun Feb 27, 2005 8:07 pm
I have recently pulled my engine out and got a recon on the gearbox. we put it all back together and it works great, but when the engine is off the Alt and Oil lights on the instrument panel stay on and to turn them off i have too disconnect the battery. I'm pretty sure all the wiring is right because I have gone through it all about ten times. And when the engine is on the lights turn off. If anybody can help it would be appreciated.
By the way it's a 74 Clubman 1100.
Mini Clubman, 1.3i, air con, 12" mags, pioneer sound system.
PostPosted: Sun Feb 27, 2005 8:57 pm
You have the dash power being fed from the wrong side on the fuse box, find which one it is and swap it back over the the accessories side. Simple
Aaron
PostPosted: Sun Feb 27, 2005 10:11 pm
or....
your alternator has done a diode (or some other part, cant remember what it was called)
Mine was doing exactly that same thing. Power is going back through from the alternator when it shouldnt be. I think if you disconnect the brown wire closest to the block it will stop the light from coming on. But you need the alternator fixed (prolly)
www.crazybitchracing.com
PostPosted: Sun Feb 27, 2005 10:18 pm
heres my problem, similar to yours
1. turn key on, lights go on
2. rev up, lights turn off (battery is charging)
3. turn key off (and remove), lights turn on (battery is still connected, and will drain)
4. disconnect battery, all lights off, regulator clicks off
(theres a contact in the regulator that builds up charge when the revs are high, switching it over to direct charging of battery - this is the click)
ive recently put a string from the cabin to this contact
when i leave the car, i pull the string, and it disconnects the two things
is mine like your problem?
i can tell you in more detail as to what i did if you like
Inconspicuously Conspicuous
PostPosted: Sun Feb 27, 2005 10:22 pm
Wombat I think you have two new purchasers :!:
PostPosted: Sun Feb 27, 2005 10:27 pm
plaise icksplane
PostPosted: Sun Feb 27, 2005 10:32 pm
Yer thats what I ment :lol:
PostPosted: Sun Feb 27, 2005 10:46 pm
does Mr Wombat have regulators/services to deal with this problem?
PostPosted: Sun Feb 27, 2005 10:48 pm
For him to quote :wink:
PostPosted: Sun Feb 27, 2005 10:49 pm
HAH cant wait for his comment
PostPosted: Sun Feb 27, 2005 11:26 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
74 modle clubmans dont have the lil black box dooke that is the reg on clubbys it is built into the alt ........
you have a wire wrong some where or as jill said the alt has gone open circut
makka
Users browsing this forum: No registered users and 70 guests
