Changing CV Joint Boots https://www.ausmini.com/forums/viewtopic.php?f=2&t=49075 |
Page 1 of 2 |
Author: | superSeven [ Fri Jan 09, 2009 12:34 am ] |
Post subject: | Changing CV Joint Boots |
Hi, Just been playing under the mini and noticed one of the outer CV Boots has split. The inner joint is the type which has u-bolts (I think).. and the car has 7.5" disc brakes. Whats the easiest way to replace the boot...? can I just disconnect the inner coupling and slide the new boot on? Or is it more complicated than that? I don't really fancy taking apart the front end of the car (again). The car is going in for RWC in the afternoon today, so it's bound to be picked up then, so would like to get it sorted on Saturday/Sunday. Also which boots would you recommend.. I noticed Lindsay at minis plus has silicon ones, $29 for 2, with grease and metal straps.. I think we need a how-to for this! ![]() Tim. |
Author: | Gadgets mini [ Fri Jan 09, 2009 10:05 am ] |
Good idea take lots of photos as you do it ![]() that way when you do the how too your descriptions will make sense I my self would have the foggiest how to do it so look forward to a how to post so if i need to do it in the future i can have a go at cocking it up before ringing my mechanic mate ![]() |
Author: | superSeven [ Fri Jan 09, 2009 10:21 am ] |
yeh will definately take photos and do a how-to.. even if its so I can remember how to do it for the other side when it fails.. |
Author: | Blokeinamoke [ Fri Jan 09, 2009 10:50 am ] |
just did mine in dec - this is what I did about and hour a side - wheel off - drum off - if drum braked - remove nut and split pin that retains the hub - remove hub - disconnect ball joints - disconnect steering arm - diconnect brake line - remove entire brake and hub assembly - remove drive shaft from spined flanged at the cv end - replace cv boot play backwards to reinstall everything - add top up and bleed brakes |
Author: | Mini_Special [ Fri Jan 09, 2009 11:25 am ] |
You can actually remove the shaft from the car with the bottom ball joint still attached. I usually disconnect teh top arm after i have loosen the nut/ washer. Then remove the inner joint/pot joint/hardy spicer. Disconnect top BJ Remove CV nut/washer Remove shaft Install new boot Re-Insatll paying extra carefull attention to the shaft going back into teh hub/drive flange. It is a little more fiddly doing it this way but it means you dont have to remove the whole hub assy hopefully. |
Author: | simon k [ Fri Jan 09, 2009 1:13 pm ] |
blokeinamoke wrote: - remove drive shaft from spined flanged at the cv end
do you mean you removed the driveshaft from the outer CV joint? there should be a circlip at the end of the driveshaft that makes it just about impossible to remove the shaft without damaging the CV and/or breaking the circlip |
Author: | Wombat [ Fri Jan 09, 2009 1:29 pm ] |
When putting the engine back into the car and the drive shafts are separate- do you add the drive shafts to the motor then fit to hubs or connect to hubs then fit the engine end? |
Author: | simon k [ Fri Jan 09, 2009 1:33 pm ] |
Wombat wrote: connect to hubs then fit the engine end
likewise to what I said above, it takes a bit of a knock to get the driveshaft into the outer CV joint, and sometimes a bit of fiddling to get the circlip to line up. I put the CV in the vice and pop the driveshaft in, then assemble the front-end |
Author: | Blokeinamoke [ Fri Jan 09, 2009 1:44 pm ] |
simon k wrote: blokeinamoke wrote: - remove drive shaft from spined flanged at the cv end do you mean you removed the driveshaft from the outer CV joint? there should be a circlip at the end of the driveshaft that makes it just about impossible to remove the shaft without damaging the CV and/or breaking the circlip I meant the uni end - my mistake ![]() |
Author: | superSeven [ Fri Jan 09, 2009 3:22 pm ] |
ok well next question.. is it a one-man-job? just got back from the RWC check, and failed on outer CV boot as expected (passed everything else though!! ![]() thanks for all the tips Tim. |
Author: | Blokeinamoke [ Fri Jan 09, 2009 3:40 pm ] |
yep one man job if you have the relevant stands and tools |
Author: | superSeven [ Fri Jan 09, 2009 7:06 pm ] |
just have to buy a ball joint splitter.. the daewoo broke mine. got two whole days to complete the job... how hard can it be.......... |
Author: | superSeven [ Sat Jan 10, 2009 5:15 pm ] |
half way done, taken plenty of photos... got the shaft out.. is it the norm to leave the CV joint attached to the shaft, and slide the new boot over the splined end? looks easier than knocking the cv joint off the drive shaft thats all... oh and is there any way to clean the CV joint as it's been run for a while i guess with the split boot.. can i just degrease, wash out, dry, and then grease it back up with the grease in the kit? thanks for the advice thus far! once again, couldn't be done without ausmini. eww greasy keyboard. |
Author: | Mearcat [ Thu May 21, 2009 4:11 pm ] |
Did you end up doing a How To for this? I see nothing in the How To section ![]() |
Author: | simon k [ Thu May 21, 2009 5:11 pm ] |
Mearcat wrote: Did you end up doing a How To for this? I see nothing in the How To section
![]() don't think so, but all the details above will get you through the job if you need to do it, then you can have credit for the how to ![]() regards to your signature, 6' 1" is a bit short to be driving a mini, 6" 4' is better ![]() |
