It is currently Sun Aug 03, 2025 10:46 pm
 Post subject: disc brakes
PostPosted: Sun Jan 11, 2009 10:51 am
hey just wondering if any one could tell me where the small spring goes in the ball joints im guessing it goes in the lower ball joint assembly thanks
PostPosted: Sun Jan 11, 2009 11:08 am
correct spring goes in the lower ball joint :D
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Jan 11, 2009 11:12 am
cheers thought so
PostPosted: Sun Jan 11, 2009 12:40 pm
When shimming the lower joint, do so with the spring out. When you get it right, then refit the spring.
It's there as an anti-rattle device only, it does not affect the ball to socket clearance.
PostPosted: Sun Jan 11, 2009 2:43 pm
is this right the bearing spacer inbetween the bearing doesnt even touch the outher bearing? or is this only for drum brakes? and also the iner seal the bit that protrudes face inwards? and the bearings tapper inwards
PostPosted: Sun Jan 11, 2009 7:52 pm
I did mine the other day. Was worried as it was real tight and notchy bur when I added another shim it was free and easy. Thought they are meant to be tight but smooth. I am 90 % sure that made no sense.
PostPosted: Sun Jan 11, 2009 8:12 pm
It's important to do these bearings right or they won't last at all.
See my how-to thread- http://www.ausmini.com/forums/viewtopic.php?t=40640
Users browsing this forum: Tezmini62 and 90 guests
