It is currently Wed Jul 23, 2025 8:16 am
 Post subject: bearings
PostPosted: Mon Jan 12, 2009 6:21 pm
just wondering on metro turbo brakes do you need the inner oil seal spacer because i dont think the kit came with one only inner and outer seals and a bearing water shield
PostPosted: Mon Jan 12, 2009 6:34 pm
Timken bearings have a wide spacer there (about 5mm wide).
Ball bearings have a thin one, about 2? mm wide.
The spacers don't come in the bearing kit, either find some or do without, if so just fit inner seal until barely flush.
