It is currently Wed Jul 23, 2025 5:05 pm
Trash or Cash?
Thrash 41%  41%  [ 14 ]
Cash 18%  18%  [ 6 ]
Asparagus 41%  41%  [ 14 ]
Total votes : 34
 Post subject: Thrash or Cash
PostPosted: Sun Jan 11, 2009 3:04 pm
I have just blown my third clutch in just over a year on the Moke. I know whats causing it - me - thrashing the hell out of it off the line and out of corners.
So what would you do - change your driving style or just buy another clutch and continue to drive like a hooligan?
PostPosted: Sun Jan 11, 2009 3:10 pm
Fix it properly. Use a Cooper S diaphragm, an AP genuine clutch plate and set it up so the diaphragm is FLAT when assembled.
See http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
for how to do it properly. :wink:
Or... bring here, me fix. 8)
My driving style (was) not gentle, but I have only once killed a mini clutch.
Maybe you need let the clutch out faster & allow the tires to feel some of the pain?
PostPosted: Sun Jan 11, 2009 3:43 pm
yep - I used that like last time you suggested Doc :wink: - but the suggested parts list might get a gurnsey this time.
also the weak handbrake (now fixed) and a lot of hills may have a significant contributor.
PostPosted: Sun Jan 11, 2009 3:55 pm
It took even me 5 years to kill the clutch in the LS, and who knows how old it was before I bought it...
PostPosted: Sun Jan 11, 2009 3:56 pm
you obvioulsy werent trying hard enough :P
PostPosted: Sun Jan 11, 2009 4:23 pm
i drove like a Sedated mad man a little heavy footed for 2 1/2 yrs didnt have a problem with clutch hopefully i will have the same luck when i get it replaced along with the Overhaul in a couple of months.
PostPosted: Sun Jan 11, 2009 4:58 pm
No mechanical sympathy...that's the problem here!
PostPosted: Sun Jan 11, 2009 8:58 pm
Slow-Po
You should go for a drive with BIAM :shock: - he drives everything as if its a rental car. :lol:
As for his clutch technique, it's similar to Josh MiniMad's. :lol:
PostPosted: Sun Jan 11, 2009 10:01 pm
Say no more :lol:
PostPosted: Mon Jan 12, 2009 12:03 pm
There are a number of different spring plates with differing strength of springing. They are identified by colour. I use a grey one (strongest) in my race car to help limit slippage.
A stronger spring plate should help your clutch last longer but will make it heavier.
Pete
PostPosted: Mon Jan 12, 2009 12:08 pm
poeee wrote:
Say no more :lol:
Good Technique then :P
I've never killed a clutch on the 1152 so ner :P ..i let the drivetrain feel the pain hence driveshafts are not my friend at the moment..
PostPosted: Mon Jan 12, 2009 1:38 pm
Mini Mad wrote:
poeee wrote:
Say no more :lol:
you betcha :wink:
PostPosted: Mon Jan 12, 2009 7:22 pm
how many is it now that you've TWISTED??? :P
78 Leyland Mini - Prince
PostPosted: Mon Jan 12, 2009 8:09 pm
Slow-Po
At least Josh MiniMad is putting out some decent horsepower, BIAM's moke on the other hand smokes the car cover more than the tyres. :D
BIAM - have you ever considered whether your "Goodride" :lol: tyres giving too much grip and not enough slip, hence the strain on the clutch? :wink:
