It is currently Fri Aug 01, 2025 1:47 am
 Post subject: rover heater.
PostPosted: Tue Jan 13, 2009 2:42 pm
so where is the best place to buy the pipes.
or what will i need..
do i need a heater tap or anything with the rover heaters?
i bought a this from steve with a rover engine.
PostPosted: Tue Jan 13, 2009 2:47 pm
What year engine?
PostPosted: Tue Jan 13, 2009 2:53 pm
i dont know.
whats the year needed for harly?
i did post in that other thread also for yah.
PostPosted: Tue Jan 13, 2009 2:58 pm
Same as Moke heater?
PostPosted: Tue Jan 13, 2009 3:01 pm
Up until '92 the heater tap was on the engine head, and the water hose went in one side of the heater and back out the other.
After 92 I think it was changed so that both hoses (water in and out) are on the passengers side, and the heater tap is inside the car.
PostPosted: Tue Jan 13, 2009 3:14 pm
ok. i will have to ask steve at bricks what my engine is then.
where do you normaly buy the pipes from though anyways.
im in Qld
PostPosted: Tue Jan 13, 2009 3:22 pm
High heel ninja
The pipes you refer to are rubber heater hose, buy it at any auto spares place. 1/2 inch is the size needed.
Doogie
PostPosted: Tue Jan 13, 2009 3:26 pm
thanks doogie.
PostPosted: Thu Jan 15, 2009 10:25 am
ok the engine is a 1994, harley
with twin carbies
PostPosted: Thu Jan 15, 2009 10:49 am
In that case the water will flow from the thermostat housing into the heater and then back ot into the lower radiator hose.
If you have the correct heater the hose inlets and tap should be on the left side.
If not, you can still change it but you'll still need the right tap.
Do you have a water heated inlet manifold?
PostPosted: Thu Jan 15, 2009 11:08 am
im not sure..
they are 1-1/4 twin su's on the manifold.it is the kind that can not be adapted to bigger su's via drilling & has a hole for my rover booster.
it did come of a rover mini in the uk. not sure what year though.
i can go have a look what am i looking for that indicates it would be water cooled.
the heater i have is like between 86 & 89 got it from steve at bricks.
PostPosted: Thu Jan 15, 2009 11:11 am
the bottom radiator hose has an extra hose coming of it with a metal thing in it.
this rover engine confuses me.
i'm so close to this bad boy being done..
PostPosted: Thu Jan 15, 2009 11:44 am
The 1994 engine would've had an injection setup from the factory. Because of this, if it still has its factory fitted head it wont have a hole in the top drivers side for the heater line.
Water heated manifold is easy, are there two 1/2 inch holes on it for hose fittings?
Now, just thinking, you dont actually need a heater tap, but it certaily dont hurt.
It sounds like you have the radiator hose from the 94 engine. It has two hoses hanging off the side, one for heater and one for manifold. If you dont have a water heated manifold then leave one of them blocked.
PostPosted: Thu Jan 15, 2009 3:00 pm
Yes it did have injection. but has been converted to carbs.
nah it is not a water cooled manifold.
only one hole that plugs the booster pipe.
thats the pipe of my rad.
the drivers side of the engine, not sure how explain it. it has a small metal tube like thing sticking up where i would assume water or part heater pipe pops on going into what looks like a heater tap.
the head looks the same as my fathers 89 rover has that same plug on the drivers side going into what looks like a heater tap.
PostPosted: Thu Jan 15, 2009 3:02 pm
I aint touching that with a barge pole!
I'd hassle Steve on that one.
