It is currently Fri Aug 01, 2025 11:26 pm
 Post subject: Doorhandle clockspring
PostPosted: Fri Jan 16, 2009 12:51 pm
The clockspring used to return the roundie door handles to their horizontal position after you have opened the door....how much am I to preload this spring? Do I turn it through 90 degrees or 180 to keep the spring load on the door handle adequately?
PostPosted: Fri Jan 16, 2009 2:00 pm
90 should be fine if all your parts are clean & lubricated :wink:
PostPosted: Fri Jan 16, 2009 2:03 pm
coooool.
Lot's of loob here, there's always time for looooooobricant.
