overheating still please help https://www.ausmini.com/forums/viewtopic.php?f=2&t=49275 |
Author: | micky [ Fri Jan 16, 2009 7:35 am ] |
Post subject: | overheating still please help |
hey there im a new mini owner bought mine couple of days ago its got the 998 motor and its been overheating. I put in a new thermostat and flushed the radiator no change. there are no leaks I can see either. would someone be able to tell me how to check the water pump and what else it could be. The car also misses and has a few dead spots when I got it 3 days ago it drove fine but was just overheating. I put in a new distributor cap and spark plugs still same thing will this car need tunning but it was fine 2 days ago. what should I check for these dead spots and miss firing. any help will be appreciated thanks guys. |
Author: | doogie [ Fri Jan 16, 2009 7:46 am ] |
Check your timing. Doogie |
Author: | ryan [ Fri Jan 16, 2009 7:54 am ] |
As doogie said, check your timing. It will cause it to miss and overheat. RYan |
Author: | carter [ Fri Jan 16, 2009 8:26 am ] |
also your points are correctly adjusted to the right thou |
Author: | micky [ Fri Jan 16, 2009 8:42 am ] |
can anyone tell me how to adjust the timing im a newbie to this. and do you mean adjust the carbie or the timing under the rocket cover and what should be the correct distance thanks guys |
Author: | superSeven [ Fri Jan 16, 2009 8:57 am ] |
where abouts are you located? you'd be best off taking it to a mechanic I believe.. or at least buy/download a haynes mini manual which will step you through the basics.. |
Author: | doogie [ Fri Jan 16, 2009 9:01 am ] |
Micky, if your new to minis it might pay to get someone who knows what there doing to give it a once over, check the timing, tappets, set the points etc etc. I'd recommend Greig @ Mini Classic @ Ermington 98747211 or Tony @ Minispares @ Padstow 97743366 It won't cost you a lot of money for a tune up. Doogie |
Author: | simon k [ Fri Jan 16, 2009 10:51 am ] |
definitely take it to a mini expert to get everything set up properly, then if you want to play, you have a good starting point to work from - any changes you do right now will be just stabs in the dark fill in your location, and we'll be able to recommend where to take it |
Author: | gafmo [ Fri Jan 16, 2009 9:51 pm ] |
superSeven wrote: where abouts are you located?
.. someone can come over and give you a run down on a few things ![]() Put a BBQ and a case of beer or two and you'll have a Great Day |
Author: | micky [ Sat Jan 17, 2009 8:18 pm ] |
im located in baulkham hills. |
Author: | david rosenthal [ Sun Jan 18, 2009 3:22 pm ] |
micky wrote: im located in baulkham hills.
damn too for away for me for free beer |
