OK story is i have a hydro set up and had no issues for the first year at standard height or slightly lower then standard.
Recently as some of you have see i changed to a 1275 A+ with a rod changer instead of remote and the more solid unis instead of the rubber cross and u bolt type (unsure of names)
every since ive had this engine ive found whilst cornering the car feels like it is jumping onto the edge of its tyre cornering as if the tyre pressure was extremely low. i had some issues with my front suspension stretching down to the road when taking off (here comes the picture i love)
From the advice of others i then let my suspension down and put competition bump stops in all round ( shockers to follow soon but shouldnt effect this issue) the car still leaned back and jumped on its tyre walls around corners so i lowered it to basically sitting riding on the bumpstops again temporary thing. But still doing this i then went for a wheel alignment finally once i had the time.
Now that i have done all this to FIX my car i have seemed to make it worse. The car is not only hoping onto its tyre walls around corners but also seems to lift at the front end whilst cornering and accelerating gently only dropping back down under heavy brakes or if i flick the steering wheel hard left and right. This also makes a loud clunk as the car drops back down. Even once the car has dropped back down the tyres still rest like they do in the picture above but i dont have adjustable suspension and the only part near that i have changed was a longer drive shaft for the different uni joint but being the same top and bottom arms the suspension set up should change????? Im going to start by greasing everything again so i hopefully free it all up but the entire front suspension was over hauled with the car in 2006 including all bearings.
Any guess is welcome this has really got me worried as its chewing my tires everytime i accelerate
Thanks to everyone in advance
