It is currently Wed Jul 23, 2025 11:13 pm
 Post subject: Inpection plate fitting
PostPosted: Fri Jan 16, 2009 6:57 pm
G'Day all,
Well the inevitable happened and due to an oil leak I have removed one inspection plate on the passenger side of the engine, fitted the new bolt gaskets (the small ones around the bolt head, not the pink rubber one for the inspection plate) and now, the bolt seems too short by 3-5mm to get the inspection plate back on.
Is there a trick to putting the inspection plate back on because I have been trying for 3 days now without any success. :?
Car: Clubbie
Engine: standard 998 rebored to + 30thou
Fade77
Nothing is foolproof to a sufficiently talented fool.
PostPosted: Fri Jan 16, 2009 7:03 pm
Grind a bit of a point on the bolt, it helps align it... :wink:
PostPosted: Fri Jan 16, 2009 7:44 pm
Thanks Doc,
But I can't even get the bolt to touch the threads, its as if the bolt is not long enough. I am afraid if I grind a point there wont be enough threads on the bolt to hold the inspection plate on. Perhaps I am misunderstanding what you mean.
Fade77
PostPosted: Fri Jan 16, 2009 7:55 pm
How old is the motor? Early 998 had different covers, cork gaskets and a fibre washer to seal the bolt.
Late Clubby ones had red silicone rubber seals and a recessed washer on the bolt with a square section seal ring.
PostPosted: Fri Jan 16, 2009 8:14 pm
It's a Late clubby with the red silicone rubber seals and recessed washer on the bolt.
Fade77
PostPosted: Fri Jan 16, 2009 8:19 pm
fade77 wrote:
G'Day all,
its the grommet around the bolt...do you still have the old one..are they differant maybe its around the wrong way
PostPosted: Fri Jan 16, 2009 8:25 pm
my apologies gafmo (and to all other readers) - I meant grommet: and they are the same as the old ones.
My technical knowledge under the bonnet consists of thingamibobs and whatchyamacallits.
I purchased them from a mini place in another state as there were/are none in Townsville.
Fade77
PostPosted: Fri Jan 16, 2009 9:00 pm
You could try a slightly longer bolt (5/16" UNF) but be careful doing it up, if its too long it will bottom out and not seal the cover or the bolt. Or, you could go to Clark Rubber and get some nitrile rubber hose trimmed to length that slides over your existing bolt and fits in the recessed washer. Take the bolt and recessed washer with you.
Had to do this recently as the gasket kit for the Clubby GT engine I have just rebuilt did not have those seals. BTW, engine returns to Townsville on Sunday.
Steve
PostPosted: Fri Jan 16, 2009 9:12 pm
its just the grommet you have changed..not the bolt, Inspection plate or the gasket around the inspection plate nothing has changed other than the Grommet.
It is a bugger in Situ..I can't give you the length...."Hmm may be I can"
Tappet Chest
• 2 x Bolts 5/16” UNF (1/2” Head, 1 1/4” long)
• 2 x Washers 5/16 PLN (5/8” OD)
http://www.ausmini.com/forums/viewtopic ... light=nuts
PostPosted: Fri Jan 16, 2009 11:55 pm
It is just the grommet and the cup washer I have changed, I did not change anything else.
I have completed the job now but it is a little on the dodgy side, I will probably have to do it again in a few months time, depending on the 'quality'.
I taped the driver side inspection plate to the block and took the bolt out, quickly replaced the grommet and put it back on. The driver side took me about 45 min to complete.
:D
Fade77
 Post subject: ja
PostPosted: Sat Jan 17, 2009 8:46 am
somtimes the simple jobs can be tricky....
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Sat Jan 17, 2009 9:39 am
Rover Cooper
Take a pic on your phone, so us learners can see what you are chatting about, please, or just the general location under the hood.
PostPosted: Sat Jan 17, 2009 9:43 am
Davo, the rover engines dont have inspection covers.
PostPosted: Sat Jan 17, 2009 11:11 am
Pretty sure A+ 998s do.... I used to own one.
Users browsing this forum: No registered users and 117 guests
