It is currently Fri Jul 18, 2025 11:56 pm
 Post subject: '79 wiper motor parts?
PostPosted: Fri Jan 23, 2009 5:23 am
Hi guys,
Has anybody got a supplier for Lucas wiper motor overhaul parts please? Two speed with self park.
Regards
Al
PostPosted: Fri Jan 23, 2009 7:17 pm
Al,
I googled this off a Wolseley forum, not used them but might be worth a call..
KB Classic Parts -
Lucas, Prestolite, Bosch, Auto-Lite, Delco-Remy, Ducieller, Paris-Rhone, S.E.V., Butler's, C.A.V.
Armatures for generators, starters, windscreen wiper motors, fan motors, fuel pumps
Bushes for generators & starters ( standard sizes & lengths and .007 for undersized shafts), wiper motors, wheel boxes
Brushes for generators, starters, alternators, wiper motors
Bendix drives - 1920 - 30, also springs, lock washers, studs, drive head sleeves
Clutch drives - 1940 -50, 3 & 4 and multispline, 9 teeth to 13 teeth
Ignition - Coils, caps, contacts, condensers, rotors, brush & springs for cap
Distributor Parts - Shafts, A/A springs, Cams, breaker plates, HT term nuts, LT leads, drive dogs, weights, vacuum units
Regulators - RB106, RB 108, RB310, RB340 to suit generators, Contact sets, covers, resistors, screws, 4TR to suit alternators
Lights / Lamps - Head lamps, light units - semi and sealed. H/L rims, gaskets, W clips, retaining rims. Side and flasher lamps, lens, gaskets, interior lamps. Stop, tail and flasher lens, gaskets and screws. Repeater lamps and lens. Number plate lamps, parts, warning lamps, bulbs, bulb holders, grommets.
Flasher Units - 2 and 3 pin round or square types. Stop lamps, indicatores - 6 / 12 / 24 volt
Fuse Boxes - Lucus and others
Generators - Armatures (new & rewound), Filelds (C35 / C39 / C40 / C42 / C45), Brackets (C & D Ends), bearings, pulleys, fans, terminal posts, pole shoe screws, thrust washers
Starters - Armatures, fields, terminal posts, pole shoe screws, C/E brackets, brake kits, povit pins / nuts / levers, solenoids & caps, stop collars, circlips, shaft nuts
Switches - Push/Pull, Startes, H/Lamp, Wiper, Wiper/Washer, Washer, Hazard, Flasher, Flasher/Horn/Hi Beam combo, Boot lamp, Door, Heater, Ignition, Ignition/Start, Fog Lamp, Reverse Lamps, Stop Lamps - Mechnical & Hydraulic, Hand Brake warning, Dipper, Panel Lamps, Solenoid Starters, KNOBS for all above
Ammeters - 2" and 1.5" 30-0-30 1/3 Quadrant types
Alternators - D/Ends, Slip Ring End brakets, Slip Rings, Bearings, Brushes & Brush Boxes, Heatsinks with Diodes, Stators, Rotors, Terminal kits, Fans & Pulleys
Windscreen Wipers - Brushes & Brush gears, Parking switches, Armatures, Brushes, Fixing studs, Con Rods, Fields, Shafts & gears, Switch contacts, Wiper arms, Wiper blades, Wheel Boxes & parts, Wiper cover switches
Cable Accessories - Bulbs - Fuses
Delivered by Australia Post - Quick and Economical
KB Classic Parts
Automotive Electrical Consultant & Supplier
Kev & Eileen Baker
2 Margaret Street
Witta vai Maleney 4552
Ph 0754 944 221 Fax 0754 944 114
PostPosted: Fri Jan 23, 2009 7:36 pm
Does he sell this?
PostPosted: Sat Jan 24, 2009 6:25 am
Hi Kev,
Thanks, that looks to be a very useful sight. Certainly worth a go. I'll let you know how I get on.
Regards
Al
