It is currently Sun Jul 20, 2025 1:49 am
 Post subject: occassional missing
PostPosted: Sat Jan 24, 2009 4:43 pm
Hi guys, My mini is doing an occastional miss. when I floor the throttle to the ground it sometimes misses. If i take my foot off the accellerator then reaply it, it will be fine! Any ideas?
PostPosted: Sat Jan 24, 2009 5:20 pm
try checking a few of the following, i had a similar problem
have you got enough dashpot oil in your su(if running su/s)?
if you dont have enoguh dashpot oil the mixture leans as soon as you flaten your foot making a flat spot or miss in some cases.
what is the condition of your condensor and points? its extremly inportant to replace the condensor everytime you replace the points, i have seem then die before creating a miss or in extreme cases completly stop the motor running.
are your spark plugs carboned up?
regards matt
PostPosted: Sat Jan 24, 2009 5:56 pm
Check your plug gaps are not too wide.
Should be .025" for stock ignition, but if running electronic you can open them up a bit. I set them to .032" with a Pulsar dizzy.
Watch it if buying blister packs of plugs, often they are gapped at 1.1mm for modern engines. You need to reset them.
