It is currently Mon Jul 21, 2025 12:30 pm
 Post subject: Tapping noise
PostPosted: Sat Jan 24, 2009 3:07 pm
My vans developed what sounds like a tapping noise.
It sounds like a stuck hydraulic lifter in an old Holden six but the sound only emits through the exhaust, not from the engine bay, from about 2000 to 2500rpm.
I first noticed it after I checked and adjusted some valve clearances.
After hearing the new noise I rechecked the gaps in case I buggered something up but they're all OK.
Any ideas?
Image Image
PostPosted: Sat Jan 24, 2009 3:56 pm
maybe its simply moving around and you need to tighten your mounts?
just a thought
PostPosted: Sat Jan 24, 2009 6:05 pm
Maybe its the TAPPETS ???
DICK
PostPosted: Sat Jan 24, 2009 7:52 pm
:roll:
Image Image
PostPosted: Sat Jan 24, 2009 8:22 pm
I had an odd tapping noise at idle, it was the vacum advance intermitently moving as I had a weber without a cross over vacum pipe, so the vacum was 'one, two, nothing nothing, one two.....' if that makes sense, just sounded like a tappet but slower
Cool stuff!!
Users browsing this forum: 68+86auto, Bing [Bot] and 93 guests
