Idler gear problem - what's the go? https://www.ausmini.com/forums/viewtopic.php?f=2&t=49567 |
Author: | Wombat [ Sun Jan 25, 2009 2:40 pm ] |
Post subject: | Idler gear problem - what's the go? |
Might remember before Christmas I was haveing problems getting the right idler gear clearance. Only had 0.001" clearance with the thinest shims. So I had one shim ground down by 0.003" expecting 0.004" clearance. Well there is now ZERO clearance - gear spins by hand OK so it's not binding (before it felt stiff). The idler gear has one long and one short shaft. I have a Cooper box with an idler gear in it but it is short/short shaft. Anyway I tried that in place and I have 0.022" clearance ![]() |
Author: | DOZ [ Sun Jan 25, 2009 2:46 pm ] |
Might not be the problem but i recall the gasket normally included with the set is the wrong thickness (too thin) - I always had to buy one separately Daniel |
Author: | Wombat [ Sun Jan 25, 2009 3:04 pm ] |
I'm using the pink one which is supposed to be the thickest |
Author: | DOZ [ Sun Jan 25, 2009 3:22 pm ] |
The one I use in the mable maroon/creamy coloured one. In fact I have never adjusted an idler gear clearance (if the original gear/washers were used in gear casing before) using this type of gasket - NB I haven't bought a new one for about 10 years, still had a couple in my shed until recent clear out. Daniel |
Author: | drmini in aust [ Sun Jan 25, 2009 4:42 pm ] |
Measure the gasket, the red/pink ones used to be .035" or so but they are thinner now. Find a thicker gasket than what you have, go pester Matt Read.... ![]() |
Author: | TheMiniMan [ Sun Jan 25, 2009 5:27 pm ] |
hee hee,,, yeah i`m anal about end float on idlers & primary gears... & yeah i have a whole variety of different thickness primary case gaskets |
