Photo request https://www.ausmini.com/forums/viewtopic.php?f=2&t=49597 |
Author: | Harley [ Mon Jan 26, 2009 4:28 pm ] |
Post subject: | Photo request |
Hello peoples! Just wondering if anybody out there is able to provide me a photo (or better yet the actual thing!) of a clubman door lock barrel? I could also use measurements and if possible, I'd like to know what the door looks like on the inside to hold it in. Is it just a shaped hole or is something welded inside? Thanks. ![]() |
Author: | DOZ [ Mon Jan 26, 2009 4:42 pm ] |
Post subject: | Re: Photo request |
Harley wrote: Hello peoples!
Just wondering if anybody out there is able to provide me a photo (or better yet the actual thing!) of a clubman door lock barrel? I could also use measurements and if possible, I'd like to know what the door looks like on the inside to hold it in. Is it just a shaped hole or is something welded inside? Thanks. ![]() The hole is round but with two flattened sides - imagine a round chocolate cream cake (3 layers) and cut two pieces off each side shaped like the harbour bridge, whats left is what the hole looks like. There is nothing special about the door, the lock is held by a spring with two ears that clamp it to the panel ![]() Daniel |
Author: | 1310/71 [ Mon Jan 26, 2009 9:23 pm ] |
Nice photo Doz, but didn't he want the actual lock barrel? ![]() |
Author: | DOZ [ Mon Jan 26, 2009 9:38 pm ] |
1310/71 wrote: Nice photo Doz, but didn't he want the actual lock barrel?
![]() Yes - but I don't have one. But he also wanted to know what the inside of the door looks like - it's the same as the outside hence my photo of the door I chucked out on the tip run. Daniel |
Author: | Dylans Clubby [ Mon Jan 26, 2009 9:41 pm ] |
got ya covered, just gimme a few minutes ![]() |
Author: | Dylans Clubby [ Mon Jan 26, 2009 10:38 pm ] |
ok here we go... originally i had reservations about posting pictures of my door lock, but then i remembered there are only three or four different keys anyway ![]() ![]() ![]() ![]() this notch at the back goes around about a quarter of the way. 2mm wide ![]() the tabs are 1mm apart ![]() diameter where taper starts: 7mm diameter where taper stops (eg, that hole...): 5mm ![]() total length: 31mm width of chrome cap (bottom) 3mm (top) 2mm with of that second lip that goes around the bottom: 2mm ![]() ![]() here's what it looks like with its key in ![]() and from the bottom ![]() |
Author: | Dylans Clubby [ Mon Jan 26, 2009 10:39 pm ] |
ok so it took nearly an hour. shutup ![]() |
Author: | Harley [ Tue Jan 27, 2009 7:35 am ] |
Dylan you are a legend in your own undies! ![]() That helps immensely! Thanks a lot! |
Author: | poeee [ Tue Jan 27, 2009 8:55 am ] |
Harley wrote: Dylan you are a legend in your own undies!
![]() So that would be rarely a legend? |
Author: | TheMiniMan [ Tue Jan 27, 2009 9:36 am ] |
There are actually about 40 different keys My dad has the genuine key-board |
Author: | Dylans Clubby [ Tue Jan 27, 2009 2:54 pm ] |
i don't own 40 pairs of undies, what are you talking about??? |
Author: | slinkey inc [ Tue Jan 27, 2009 3:21 pm ] |
Might help a bit... http://www.minisport.com.au/prod681.htm |
