Brake Help. https://www.ausmini.com/forums/viewtopic.php?f=2&t=4962 |
Author: | Drekkus [ Mon Feb 21, 2005 7:18 pm ] |
Post subject: | Brake Help. |
I was getting a noise from one of the front wheels and when I checked it out I found the hub nut loose.I tighten and went to take it for a test drive around the block .Hit the brakes and nothing, luckily the hand brake worked. Now if I pump the brakes they come up but as soon as I release the pressure they're gone again.I tried bleeding, the brake cyclinders and hoses were new 6 months ago,a new kit put in the MC about 12 months ago and I can't see any leaks. Coincidence or did I accidentally do something when I tightened the nut. |
Author: | 13secmini [ Mon Feb 21, 2005 7:32 pm ] |
do you have discs or drums??? did you check the brake lines? may have cracked or split a line from the loose nut. |
Author: | Drekkus [ Mon Feb 21, 2005 7:43 pm ] |
Drums.The brake lines do look ok but I will check again tomorrow. |
