The Making of a Plastic Battery Cover
https://www.ausmini.com/forums/viewtopic.php?f=2&t=49670
Page 1 of 2
Author:  Wombat [ Wed Jan 28, 2009 4:20 pm ]
Post subject:  The Making of a Plastic Battery Cover
The original battery cover was looking a little 'tired'
So I bought a cheap plastice battery box from Supercheap ($12.95 on special)
Using the old box as a guide I marked out the shape and cut it out using a dremel - a hacksaw sort of did the job but the box was 'soft' and moved about a lot. Could use a Stanley knife but although it cuts easy it is hard to control and you can overcut easily.
I used the Stanley to trim off the burs and neaten up the curved bits.
The finished job.
Author:  jess [ Wed Jan 28, 2009 4:27 pm ]
Looks great!
Author:  Tombo [ Wed Jan 28, 2009 4:31 pm ]
Thats some nifty work. :roll:
Author:  rehab1964 [ Wed Jan 28, 2009 5:07 pm ]
spiffy :wink:
Author:  chopchop [ Wed Jan 28, 2009 6:20 pm ]
just like a bought one!
Author:  minidrifter [ Wed Jan 28, 2009 6:48 pm ]
very nice! will have to make one myself now!
just a question, why did you cut out a semi-circle hole after where the lead goes through? (In the last pic next to the bolt)
Author:  Wombat [ Wed Jan 28, 2009 7:35 pm ]
That was on the original and gives room for the end of the J hook of the hold down to stick out and access for the cover strap it clip on the other hole in the metal tab next to the battery compartment
Author:  Timinik [ Wed Jan 28, 2009 7:36 pm ]
Interesting..
On a shell I just recently aquired, the old battery tray was cut out, and a new annealed one made to suit that style battery box (plastic liner and lid)... Lifty little idea anyway..
Author:  mini-dunger [ Wed Jan 28, 2009 9:30 pm ]
I have to do this soon, what kinda set up does a mini use to secure the battery? and also does the cover just push on top of the battery?
Author:  Wombat [ Wed Jan 28, 2009 9:39 pm ]
Battery Hold down and cover strap
Author:  Aussie Brian [ Wed Jan 28, 2009 9:44 pm ]
Wombattery covers Schmicko
Author:  mini-dunger [ Wed Jan 28, 2009 9:49 pm ]
Author:  Wombat [ Wed Jan 28, 2009 9:52 pm ]
The blue writing in my last post is a link
Author:  mini-dunger [ Sat Jan 31, 2009 3:40 pm ]
the hold down, does it go longways or across the battery?
Author:  Wombat [ Sat Jan 31, 2009 4:30 pm ]
Longways with two short J bolts down to the holes on the sides of the box each end
