Removing interior glue????? https://www.ausmini.com/forums/viewtopic.php?f=2&t=49701 |
Author: | Dave68Mini [ Thu Jan 29, 2009 10:53 am ] |
Post subject: | Removing interior glue????? |
Hi All, I was wondering if anyone has any tricks for removing the glue and hair that's used to attach the interior trim in the car. I dont want to use paint stripper as it will just create more work. Cheers Dave |
Author: | jess [ Thu Jan 29, 2009 10:55 am ] |
metho maybe? Are you talking about the glue that holds the carpet etc? |
Author: | Dave68Mini [ Thu Jan 29, 2009 11:14 am ] |
Hi, Yep, it's the glue that holds the trim on the dash board and around the wheel arches. Thanks Dave |
Author: | Boyracer [ Thu Jan 29, 2009 11:21 am ] |
I've recently removed insulation from under a bonnet on a non-mini. Believe it or not, a stainless steel painters scraper is the best tool. I didn't like the idea when I was told it, but it did a great job. |
Author: | bamnfi [ Thu Jan 29, 2009 11:43 am ] |
might sound weird, but eucalyptus oil is the best thing to get rid of glue. End up smelling like a koala tho. |
Author: | 66S [ Thu Jan 29, 2009 12:20 pm ] |
I use Shell Toluol/toluene and that takes off the softer stuff. Where it has gone rock-hard, I use a 2" Scotchbrite pad on my small air die grinder. Done gentley, it does no harm to the paint. Regards Al |
Author: | Mick [ Thu Jan 29, 2009 12:26 pm ] |
Turps will dissolve it, not as fast as koala farts(eucalyptus oil) however. |
Author: | Hanra [ Thu Jan 29, 2009 12:43 pm ] |
Ive used 3M Contact Adhesive Remover in an aerosol can. Not sure how it would go on old glue, but when I was doing my interior with fresh contact adhesive it came in very handy. |
Author: | Mick [ Thu Jan 29, 2009 12:45 pm ] |
Hanra wrote: Ive used 3M Contact Adhesive Remover in an aerosol can. Not sure how it would go on old glue, but when I was doing my interior with fresh contact adhesive it came in very handy.
The solvents will get through it, have to keep it wet with the stuff while it works. I removed some after 8 years around my rear window. |
Author: | Dave68Mini [ Thu Feb 05, 2009 7:15 pm ] |
Thanks for all the suggestions. I'll let you know which one works Dave |
