Storing Brake bits
https://www.ausmini.com/forums/viewtopic.php?f=2&t=49785
Author:  Wombat [ Sat Jan 31, 2009 4:37 pm ]
Post subject:  Storing Brake bits
Can you use WD40 in items such as a brake booster after overhauling it and waiting to intall it? I did one about 18 mths ago and just pulled it apart again cause I didn't like the paint job and am doing it again. I found the small amount of brake fluid had absorbed moisture and turned to jelly. Wondering what to use when I put it back together.
Author:  Morris 1100 [ Sat Jan 31, 2009 4:51 pm ]
Rubber grease or brake assembly lube.
Author:  drmini in aust [ Sat Jan 31, 2009 5:37 pm ]
What he said ^^^ :wink:
Keep hydrocarbon based products like grease, oil, degreasers and WD40 etc well away. It rots the rubbers....
Author:  Mick [ Sat Jan 31, 2009 6:41 pm ]
I rubber greased the arse out of all the brake components before storing them, rubber grease washed straight out with the first bleed of the brake system. I thought air might get trapped in there binding with the grease, but no problems. The complete bleed was finished in 20 minutes front to back using a jar and rubber hose.
Author:  Tombo [ Sat Jan 31, 2009 7:03 pm ]
Once rubber greased wrap bits in baking paper. Chuck in a pack of silica gel from a medicine bottle if you have access.
