It is currently Fri Aug 15, 2025 12:53 pm
PostPosted: Wed Feb 04, 2009 9:40 am
Hi, im not sure how to pull the following apart, and just guessing with a big hammer and screwdriver may butcher it :lol:
So advice is the answer
A
Pull the bearings out of the middle
B
Pull bearings out of this one
C
Pull the plate of the end of the inside of this brakebooster
Ive never pulled these apart and am making up as i go and have nearly butchered other stuff because i didnt know... :oops: :oops: :oops:
So Thanks for your help, its very much appreciated
Brenton
PostPosted: Wed Feb 04, 2009 9:56 am
Don't know about the booster - but the bearings can be tapped out from the back.
You'll need something solid that is softer than the cast bearing housing - ie a Brass Drift (a piece of Brass rod), a hammer and a solid surface to work on. Then keep working your way around the bearing (say 12, 4 and 8 o'clock positions) tapping it out a little at a time.
When I tried to file a new edge onto a large cheap screwdriver, I found that it was made of plated brass. This now has the flat end cut off and the plating filed off - bonus is that the shaft goes all the way through the handle to hit with the hammer while retaining a more ergonomic handle. Hows that for finding a good use for a Supercheap product :lol: :lol:
PostPosted: Wed Feb 04, 2009 10:34 am
Booster - Just done it twice - 1st time hard second dead easy
Dead easy way - remove circlip from around where the shaft goes through the centre - pull out shaft and spring (has rubber cup on end)
undo nuts and it all comes apart :wink:
By the way the hard way is to try and undo the nuts through the spring :oops:
David L
PostPosted: Wed Feb 04, 2009 10:42 am
Oh ok i found the circlip, i didnt even know it was there...
So i need to buy a brass drift to punch out the bearings..
Thanks for that
Brenton
Users browsing this forum: No registered users and 199 guests
