How do i pull these apart?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=49933 |
Author: | Bubbacluby [ Wed Feb 04, 2009 9:40 am ] |
Post subject: | How do i pull these apart?? |
Hi, im not sure how to pull the following apart, and just guessing with a big hammer and screwdriver may butcher it ![]() So advice is the answer A Pull the bearings out of the middle ![]() B Pull bearings out of this one ![]() C Pull the plate of the end of the inside of this brakebooster ![]() Ive never pulled these apart and am making up as i go and have nearly butchered other stuff because i didnt know... ![]() ![]() ![]() So Thanks for your help, its very much appreciated Brenton |
Author: | VicMini13 [ Wed Feb 04, 2009 9:56 am ] |
Don't know about the booster - but the bearings can be tapped out from the back. You'll need something solid that is softer than the cast bearing housing - ie a Brass Drift (a piece of Brass rod), a hammer and a solid surface to work on. Then keep working your way around the bearing (say 12, 4 and 8 o'clock positions) tapping it out a little at a time. When I tried to file a new edge onto a large cheap screwdriver, I found that it was made of plated brass. This now has the flat end cut off and the plating filed off - bonus is that the shaft goes all the way through the handle to hit with the hammer while retaining a more ergonomic handle. Hows that for finding a good use for a Supercheap product ![]() ![]() |
Author: | Wombat [ Wed Feb 04, 2009 10:34 am ] |
Booster - Just done it twice - 1st time hard second dead easy Dead easy way - remove circlip from around where the shaft goes through the centre - pull out shaft and spring (has rubber cup on end) undo nuts and it all comes apart ![]() By the way the hard way is to try and undo the nuts through the spring ![]() |
Author: | Bubbacluby [ Wed Feb 04, 2009 10:42 am ] |
Oh ok i found the circlip, i didnt even know it was there... So i need to buy a brass drift to punch out the bearings.. Thanks for that Brenton |
