It is currently Sun Jul 27, 2025 2:30 pm
 Post subject: 17 ACR Alternator
PostPosted: Wed Feb 04, 2009 1:49 pm
just fitted one, does anyone know if some wires need to be cut friom regulator ,as this alternator is self regulating , minisport reccommend this, now i have a build up of white powder from bty, anyone had similar experience.
i beleive its the earth wire black and the two yellow and browns joined together, electrics not my thing any help or reccommendations would b appreciated thanks
Ruling the bends and bending the rules since 1959
PostPosted: Wed Feb 04, 2009 5:49 pm
I have a lot of powder on the negative terminal too. does this mean its wired wrong? or the alternator is stuffed?
blokeinamoke wrote:
 Post subject: Re: 17 ACR Alternator
PostPosted: Wed Feb 04, 2009 10:57 pm
scudley wrote:
just fitted one,
fitted one to what, exactly? Ex-generator wiring loom? More info needed.
PostPosted: Thu Feb 05, 2009 6:12 am
I've done this on my car.
Connect the brown/yellow (indicator light) wire to the small spade lug on the alternator, and the 1 or 2 brown wires to the big ones.
The green/blk? field wire from the regulator to the alternator is not used, this alternator is self-regulating. Just tape it up.
You can leave the old regulator there to look period correct or just unplug and remove it, it won't affect the alternator and charging.
