It is currently Sun Jul 27, 2025 8:36 pm
 Post subject: 17 ACR Alternator
PostPosted: Wed Feb 04, 2009 1:49 pm
just fitted one, does anyone know if some wires need to be cut friom regulator ,as this alternator is self regulating , minisport reccommend this, now i have a build up of white powder from bty, anyone had similar experience.
i beleive its the earth wire black and the two yellow and browns joined together, electrics not my thing any help or reccommendations would b appreciated thanks
Ruling the bends and bending the rules since 1959
PostPosted: Wed Feb 04, 2009 5:49 pm
I have a lot of powder on the negative terminal too. does this mean its wired wrong? or the alternator is stuffed?
blokeinamoke wrote:
 Post subject: Re: 17 ACR Alternator
PostPosted: Wed Feb 04, 2009 10:57 pm
scudley wrote:
just fitted one,
fitted one to what, exactly? Ex-generator wiring loom? More info needed.
PostPosted: Thu Feb 05, 2009 6:12 am
I've done this on my car.
Connect the brown/yellow (indicator light) wire to the small spade lug on the alternator, and the 1 or 2 brown wires to the big ones.
The green/blk? field wire from the regulator to the alternator is not used, this alternator is self-regulating. Just tape it up.
You can leave the old regulator there to look period correct or just unplug and remove it, it won't affect the alternator and charging.
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62 and 98 guests
