It is currently Wed Jul 30, 2025 2:04 am
 Post subject: Hepolite Pistons
PostPosted: Wed Feb 04, 2009 6:22 pm
Im currently Doing a rebuild and have a set of Hepolite 040 pistons Possibly High compression.
I have been told that there quite a good piston. Im just alittle curious to see what other people have thought of them through experiance?
Really good or average?
regards Matt
PostPosted: Wed Feb 04, 2009 6:28 pm
I have built a few 1275 motors with Hepolites.
21251 (8.8:1) are cheap but not very strong, they are OK for a stocko rebuild (non-S).
21253 (9.75:1) are a better, stronger piston, similar to a Hypatec but more expensive. I recommend get Hypatecs instead if you are buying new, they are heaps cheaper. Can also get these in 73.0mm and 73.5mm.
If you are going racing or building a big HP weekend warrior, check out Russell Engineering's pistons.
PostPosted: Wed Feb 04, 2009 6:32 pm
they are 20747's
the also have stamped
413 and AE
if that says anything
they were out of my dads old engine which was built for a racing purpose. it did about 2 hours of running time
PostPosted: Wed Feb 04, 2009 6:46 pm
As the good Doc has said.....Go the Hypatecs or get a set of GR pistons if going over +60thou best you speak to the man first as to your requirements.
PostPosted: Wed Feb 04, 2009 6:48 pm
The main problem with Hepolite pistons as I see it is that you are limited in the type of piston rings you can use, As far as I know only Hepolite rings fit the piston.
They are not Chrome or Molly top rings and the ring gap is way to large straight out of the packet.
If you chose to use Hypertec pistons you have a far greater choice of quality piston rings from different manufacturers, eg Grant or Hastings.These companys offer a choice of a cast, chrome or molly top ring which can be gaped to the correct size before fitting.
Dave
PostPosted: Wed Feb 04, 2009 7:13 pm
David Vazard says that 20747 is a forged piston with a 9.7CR 6cc Dish Excellent High Performance Race Piston
Will take Hastings Rings
PostPosted: Wed Feb 04, 2009 7:17 pm
Dave
Nippon rings fit the Hypatecs too, I run them in my 1412 stroker. GR uses these in his own brand pistons.
PostPosted: Wed Feb 04, 2009 7:26 pm
20747 is "Econoguide Powermax" piston. Hepolite were the only piston manufacturer in the world to make this style of piston. On the thrust skirt of the piston there were 3 raided pads (less than.0005" high) that contacted the bore. These pads were formed when the piston was forged. This cut down friction.
You could not see these pads when the piston was new - only after the engine had been run for a couple of hours.
An extremely high quality piston.
Hope this helps. :D
PostPosted: Wed Feb 04, 2009 8:00 pm
There you go Leema,
Looks like you have a trick set of pistons there :!:
[quote="][/quote]
Nippon rings fit the Hypatecs too, I run them in my 1412 stroker. GR uses these in his own brand pistons.[/quote]
Thanks for the tip on the Nippon Rings Kevin.
It's always good to have another option :D
Dave
PostPosted: Wed Feb 04, 2009 8:17 pm
sitnlo62 wrote:
There you go Leema,
Trick set??
PostPosted: Wed Feb 04, 2009 8:19 pm
He means VF Good.... :wink:
PostPosted: Wed Feb 04, 2009 10:43 pm
Hope this helps. :D
I think i have found those 3 pads you talked about
