It is currently Mon Jul 21, 2025 2:54 am
 Post subject: Misses when hot
PostPosted: Sat Feb 07, 2009 8:04 am
After much children delivery to multiple sporting events throughout Sydney - at high speed as they were late :roll: , the Moke developed a miss at high revs when hot.
Any suggestions?
PostPosted: Sat Feb 07, 2009 8:09 am
slow down? Sorry, that's not very helpful but I couldn't resist. I had a similar problem that turned out to be a blokage in the SU's and I discovered there was no filter. It only seemed to happen in similar conditions to yours. Just a possibility to investigate.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat Feb 07, 2009 8:16 am
Electric or mechanical fuel pump ? I've had a mechanical pump start to fail on stinking hot days and lead to slight fuel starvation , was just enough to cough occasionally . There's a lot of heat trapped at the back of the motor on hot days ...
PostPosted: Sat Feb 07, 2009 8:33 am
electric fuel pump
PostPosted: Sat Feb 07, 2009 9:43 am
I had a similar problem the other day with my chain saw. I worked out that it was old fuel. Put some fresh stuff in and it was fine.
I know this dont help but it just made me think of it.
blokeinamoke wrote:
PostPosted: Sat Feb 07, 2009 9:50 am
nup - new fuel
I just did the last run for the day - so I will rest it try with fresh plugs
Again it missed with load at lhigh revs - no miss on light load
PostPosted: Sat Feb 07, 2009 9:53 am
Does it run on when you stop after it's been missing or is it behaving itself otherwise , not running hot at all or anything else ?
PostPosted: Sat Feb 07, 2009 10:01 am
nup doesnt run on - generaly behaves itself - it runs a little hot but that is due to hills around here
The poor little Moke had been running up and down these all morning loaded to the rafters
PostPosted: Sat Feb 07, 2009 10:05 am
Slow-Po
Damn, I thought this thread was about your missus when she's hot. :( :lol:
PostPosted: Sat Feb 07, 2009 10:09 am
I thought that you would think that when I posted it. I see the way you look at her :P
PostPosted: Sat Feb 07, 2009 10:19 am
Location: Burpengary,Brisbane Nth(the better side of Bribane)
any oil leaks around the electrics or plug leads, oil starts to run when it gets hot and can short things out.
https://t.me/pump_upp
PostPosted: Sat Feb 07, 2009 10:21 am
nup - but good enough idea to get off my butt and check
PostPosted: Sat Feb 07, 2009 12:10 pm
Slow-Po
You've confused with me with Tiny. :cry: :lol:
PostPosted: Sat Feb 07, 2009 3:09 pm
There's a guy in the Sprint rounds here at Mallala with the same issue in his Cooper S faker. Been hunting it for months and can't find it. If he lets it cool between sessions - its fine. But as the laps progress, the misfire gets worse and worse..
Let us know if you do figure it out!
PostPosted: Sat Feb 07, 2009 3:26 pm
Check what coil is on it now, if it's a resistor coil running without one they get hot then do just that.
Try another coil, 12V. :wink:
