It is currently Mon Jul 21, 2025 2:56 am
 Post subject: Fan direction
PostPosted: Thu Feb 05, 2009 2:19 pm
Hi,
Does anyone know which way does the thermal fan spin? Towards the headlight or towards the door?
PostPosted: Thu Feb 05, 2009 2:30 pm
If its a factory fan there is an arrow on it that says which way.
 Post subject: Fan
PostPosted: Thu Feb 05, 2009 2:45 pm
Rover Cooper
Check the angle of the blades, one side is suck and the other side is push.
PostPosted: Thu Feb 05, 2009 2:51 pm
Tomboss Breweros
Watch as it turns off, when it gets slow you will be able to tell.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Feb 05, 2009 3:40 pm
Ask Mattsmadmini he will be able to tell you :wink:
PostPosted: Thu Feb 05, 2009 4:51 pm
OK I will it check. Just put a new switch in and don't know which way it should spin. Does it usually spin at the opposite direction against the engine fan?
PostPosted: Thu Feb 05, 2009 5:02 pm
contact steve at brickworx racing
Ruling the bends and bending the rules since 1959
PostPosted: Thu Feb 05, 2009 7:49 pm
Milatsmadmini
ok look at the fan, now picture the way that would be most painful/gruesome if you were to touch it while it were spinning, thats the right way :lol:
PostPosted: Sun Feb 08, 2009 7:59 pm
I don't think it matters whether it spins clockwise or anti-clockwise, so long as it's sucking air from the engine bay and blowing it out the wheel arch.
